# Scheduled entry search trigger (Batch)
The Scheduled entry search batch trigger searches Active Directory entries on a schedule you specify. The trigger retrieves a list of entries matching the criteria you specify and processes them batches.
# Input fields
| Sample entry DN | Specify the distinguished name (DN) of a reference entry. The trigger uses this entry’s attributes as a template to define sub-fields in the Search by field and retrieve values from matching entries. |
| Trigger on | Select whether to search at a Specific interval or Specific date/time. |
| Entry search filter | Enter LDAP filters (opens new window) to define search conditions. For example, enter (ou=Dev)(objectClass=Person) to retrieve only Person entries from the Dev organization unit. |
| Batch size | Specify the number of entries to process in each batch. The default value is 100 and the maximum is 1,000 entries. |
| Limit | Enter the maximum number of entries you plan to retrieve for each trigger event. The maximum is 1,000 entries. |
| Search by | Enter values for each attribute you plan to filter by. Only entries that match all the provided values are processed. This field includes sub-fields for each attribute of the reference entry. |
ADDITIONAL INPUT FIELDS
The recipe editor generates additional input fields based on your Trigger on selection. Use these fields to specify the trigger schedule.
# Output fields
| Entries | A list of retrieved entries and their values for attributes defined by the reference entry. |
| First batch | Indicates whether the current batch is the first batch. |
| Last batch | Indicates whether the current batch is the last batch. |
Last updated: 10/14/2025, 11:14:55 PM
