# Google vault - Create record
The Create record action enables you to create a record in Google Vault.
Google Vault Create record actionGoogle Vault Create record action
Input Field Description
Object Specify the object you plan to create. Fields dynamically load based on the selected object.
The output fields are determined by the object you select in the input. Map the relevant datapills from the data tree for downstream steps.
On this page
