# Google Vault - Delete record action
The Delete record action enables you to delete a record in Google Vault.
Google Vault Delete record actionGoogle Vault Delete record action
Input Field Description
Object Specify the object you plan to delete. Fields dynamically load based on the selected object.
The output fields are determined by the object you select in the input. Map the relevant datapills from the data tree for downstream steps.
Last updated: 12/11/2025, 6:57:33 PM
On this page
