# Google vault - Remove accounts from hold
The Remove accounts from hold action enables you to remove accounts from an account-based hold in Google Vault.
Google Vault Remove accounts from hold action
| Input Field | Description |
| Hold ID | Use the Hold ID drop-down menu to select a hold from Google Vault, or enter the ID manually. |
| Matter ID | Use the Matter ID drop-down menu to select a hold from Google Vault, or enter the ID manually. |
| Account IDs | Enter a comma-separated list of account email addresses to remove from the hold. |
| Details output field | Describe custom output fields present in the details of the output schema |
| Output Field | Description |
| Code | The HTTP response status code. |
| Message | A developer-facing error message, if any. |
| Details | A list of messages that contain additional error details, if applicable. |
