# Google vault - Get record by ID record
The Get record by ID action enables you to retrieve a record in Google Vault.
Google Vault Get record by ID action
| Input Field | Description |
| Object | Specify the object you plan to retrieve. Fields dynamically load based on the selected object. |
The output fields are determined by the object you select in the input. Map the relevant datapills from the data tree for downstream steps.
