# Google vault - Search records
The Search records action enables you to search records in Google Vault.
Google Vault Search records action
| Input Field | Description |
| Object | Specify the object you plan to search. Fields dynamically load based on the selected object. |
The output fields are determined by the object you select in the input. Map the relevant datapills from the data tree for downstream steps.
