# Google vault - Update record
The Update record action enables you to update a record in Google Vault.
Google Vault Update record actionGoogle Vault Update record action
Input Field Description
Object Specify the object you plan to update. Fields dynamically load based on the selected object.
The output fields are determined by the object you select in the input. Map the relevant datapills from the data tree for downstream steps.
On this page
