# IBM Db2 - Upsert rows
This action enables you to perform an upsert, or a simultaneous insert or update, to either a single row, or to multiple rows.
The action checks if input data is in the table. If present, the system performs an update. Otherwise, it adds the data as a new row (insert).
# Upsert one row
This action upserts a single row into the selected table.
# Input fields
- Table
 - Required field
 - Select the target table/view to work with. You can also toggle the input to text mode to enter the table/view name in text.
- Columns
 - Required field
 - Columns in the selected table are then presented as input fields here. Map the required fields from the output datatree here to upsert a row with data from preceding trigger or actions.
- Primary key
 - Required field
 - Primary key value used to determine if the data is updated or inserted.<br/ ><br/ >Select a unique key column to deduplicate rows.<br/ ><br/ >When you index the selected unique key, it improves the performance of the upsert action.
# Output fields
- Rows affected
 - Number of upserted rows.
# Upsert a batch of rows
This action allows you to perform an upsert (i.e. insert or update) of multiple rows in a single step. It will check if input data exists in the table. If it is present, and update is performed. Otherwise, the data is inserted as a new row.
# Input fields
- Table
 - Required field
 - Select the target table or view. You can also toggle the input to text mode, and enter the table or view name as text.
- Rows > Rows source list
 - Required field
 - The datapill that is the source of the batch of rows to insert into the table. Can originate from any trigger or action that returns a list datapill.
- Rows > Rows fields
 - Optional field
 - Dynamically-generated list of input fields, based on the columns in the target table. Map the data from the Rows source list datapill.
- Unique key
 - Required field
 - Select a unique key column to deduplicate rows.<br/ ><br/ >When you index the selected unique key, it improves the performance of the upsert action.
# Output fields
- Rows affected
