# Microsoft Fabric - Create record action
The Create record action enables you to create the specified record in Microsoft Fabric.
Input field Description
Object Specify the object to create its record. Fields load dynamically based on the selected object.
For example, if the selected object is Lakehouse, the input schema is as follows:
Workspace ID Select or enter the ID of the workspace where the item should be created.
Display name Enter the name of the lakehouse.
Creation payload Enter the payload containing information for the lakehouse to be created.
Description Enter the description for the lakehouse.
The output fields are determined by the object selected in the input. Map the relevant data pill from the data tree to subsequent steps. For example, the output for the Lakehouse object, includes the following fields:
Output field Description
Description Description of the lakehouse.
Display name Name of the lakehouse.
Folder ID ID of the folder where the lakehouse is created.
ID ID of the lakehouse.
Properties Properties of the lakehouse include the following data. Type, Default schema, One lake files path, One lake tables path, SQL endpoint properties, Connection string, ID, Provisioning status.
Item tag The list of tags attached to the lakehouse is any.
Type Type of the item. Lakehouse in this case.
Workspace ID ID of the workspace where the Lakehouse was created.
Status Status of provisioning of the lakehouse.
Last updated: 11/17/2025, 8:59:14 PM
On this page
