# Microsoft Graph API - Create shareable link action
The Create shareable link action creates a shareable link in Microsoft Graph API. The existing link is returned if a shareable link already exists.
| Entity type | Select the entity to provide permissions to create a shareable link. |
| Site ID | Select the ID of the site to create a shareable link for. Default is to pick up sites from the communication site directory. |
| Link type | Select the type of link to create. For example, view, edit, or embed. |
| Folder ID | The ID of the folder to create a shareable link for. |
| Retain inherited permissions | Select if existing inherited permissions are retained when you share this item. All existing permissions are removed when sharing the item if set to false. |
| ID | The ID of the shareable link. |
| Roles | Any roles that associated with the shareable link, such as read. |
| Link | The shareable link URL. |
| Has password | A boolean response indicating if the shareable link requires a password to access. |
| Share ID | The ID of the resource the shareable link corresponds with. |
| Expiration date time | The date and time that the shareable link expires. |
Last updated: 3/9/2026, 5:32:32 PM
