# On-prem files - Rename file action
The Rename file action renames an existing on-prem file. You can't rename folders with this action.
| File | Select or manually enter the relative path to the file to rename. Only files can be renamed. |
| New file name | Enter a new name for the file, including its extension. |
| File name | The new name of the file, including its extension. |
| File path | The path of the file, relative to the base path defined in your connection profile. For example: /my-profile/path/renamed-file.csv. |
| File size (bytes) | The size of the file contents in bytes. |
| Created time | The time the file was created. This value is set by your OS. |
| Last modified time | The time the file was last modified. This value is set by your OS. |
