# Power BI - Create record action
The Create record action creates a record, such as a dataset, in Power BI. You can select an object and provide the required data.
| Object | Select an object to create. Fields load dynamically based on your selection. |
Output fields depend on your selected object. You can use datapills from the datatree to map values in subsequent steps.
