# Power BI - Upload PBIX file action
The Upload PBIX file action uploads a PBIX (Power BI Extension) file to Power BI.
| File contents | Enter the contents of the PBIX file to upload. |
| File name | Enter the name of the PBIX file. |
| Dataset display name | Enter the dataset display name, including the file extension. |
| Workspace | Select a workspace from the drop-down menu. |
| Name conflict | Choose an action if a dataset with the same name exists. The default is Ignore. Abort and Overwrite are only supported for RDL (Report Definition Language) files. |
| Skip report | Choose whether to skip report import. If specified, the value must be true. Supported only for PBIX files. |
| ID | The unique identifier for the uploaded file. |
