# Amazon S3 Connection
# How to connect to Amazon S3 on Workato
The Amazon S3 connector uses the AWS Signature Version 4 (opens new window) to authenticate to Amazon S3. There are two ways to connect:
- Using Access Key
 - Using IAM role
ACCESS KEY LEGACY AUTHENTICATION
Access key authentication is a legacy authentication format and we highly recommend IAM role authentication.
# Connect to Amazon S3 using Access Key
You can connect to S3 with an access key, however, the simplest method is to use an IAM role. You must provision a Workato IAM user (opens new window) and provide user credentials (opens new window) for this authentication method. Refer to Amazon documentation (opens new window) to learn how to create an IAM User.
Refer to Amazon's documentation for instructions on how to set up and manage access keys (opens new window).
# Input fields for Access Key
| Field | Description |
| Connection name | Give this connection a unique name that identifies which S3 instance it is connected to. |
| Authorization type | Select Access Key. |
| Access key ID | The ID of the user. |
| Secret access key | The secret of the user. |
| Restrict to bucket | Define which bucket this connection is restricted to. |
| Restrict to path | Use to restrict your connection to a specific bucket and object or path. This is required when the user has only limited s3:ListBucket (opens new window) access. |
| Region | Provide the region for this S3 account. |
| Download threads | The default is one thread. |
# Connect to Amazon S3 using IAM Role
Provisioning a dedicated IAM profile allows the owner of the S3 instance to grant Workato access to AWS resources without sharing AWS security credentials. It also helps to maintain permission boundaries, including controlled access to specific AWS folders and actions that are permitted by the third-party application (for example, Workato).
Workato performs operations in your Amazon S3 as this IAM role. To use the full set of triggers and actions, the IAM role should have List/Write permission to specific buckets and folders. Workato recommends to grant only the required permissions and avoid using AmazonS3AllAccess whenever possible.
# Input fields for IAM role
| Authorization type | Select IAM role. |
| IAM role ARN | The IAM role ARN.  Note: Workato generates a unique external id (for example, workato-user-84762). This value is different for every Workato user and must be provided when creating an IAM role in S3. |
# Create IAM role and ARN retrieval
Refer to the IAM role-based authentication for AWS page for instructions on how to create an IAM role for Workato and retrieve your Amazon resource name (ARN).
# Permissions
| Action | Role |
| Create connection | S3:ListAllMyBuckets |
| Create bucket | S3:CreateBucket |
| Delete file/folder | S3:DeleteObject, S3:ListAllMyBuckets |
| Download file contents | S3:ListAllMyBuckets, S3:GetObject |
| Generate resigned URL | S3:GetObject |
| Get bucket location | S3:GetBucketLocation |
| List files in bucket | S3:ListBucket, S3:ListAllMyBuckets |
| Upload file | S3:PutObject, S3:ListAllMyBuckets |
| Upload file streaming | S3:PutObject, S3:ListAllMyBuckets |
| All triggers | S3:ListBucket, S3:ListAllMyBuckets |
| Use S3 as an audit log streaming destination | S3:ListAllMyBuckets, S3:PutObject |
 Last updated: 6/5/2025, 9:49:27 PM
