# SAP Ariba - Create record action
Use the Create record action to create a record in SAP Ariba, such as a project document or bid.
COMPATIBLE APIS
The SAP Ariba connector supports multiple APIs, and each API provides access to different objects and operations. Refer to the Available APIs section to identify the APIs compatible with this action.
| Object | Select the type of object to create, such as a Document. Additional fields load dynamically based on the object you select. |
The output of this action is determined by the object selected in the input. Use the data tree in the recipe editor to see all available output fields and map them to subsequent steps.
Last updated: 4/10/2026, 3:30:11 PM
