# SAP Ariba - Delete record action
Use the Delete record action to delete a record in SAP Ariba, such as a contract workspace.
COMPATIBLE APIS
The SAP Ariba connector supports multiple APIs, and each API provides access to different objects and operations. Refer to the Available APIs section to identify the APIs compatible with this action.
Input field Description
Object Select the type of object to delete.
{Object name} ID Enter the unique identifier of the object to delete. This is typically a numeric or alphanumeric ID from SAP Ariba. You can obtain this ID using the Search objects action.
Output field Description
Success Indicates whether the record was deleted successfully.
Last updated: 11/11/2025, 5:08:44 PM
On this page
