# SAP Ariba - Get record details by ID action
Use the Get record details by ID action to retrieve record details from SAP Ariba by specifying a record ID.
COMPATIBLE APIS
The SAP Ariba connector supports multiple APIs, and each API provides access to different objects and operations. Refer to the Available APIs section to identify the APIs compatible with this action.
Input field Description
Object Select the type of object to retrieve, such as a Contract Workspace. Additional fields load dynamically based on the object you select.
{Object name} ID Enter the unique identifier of the object to retrieve. This is typically a numeric or alphanumeric ID from SAP Ariba. You can obtain this ID using the Search objects action.
The output of this action is determined by the object selected in the input. Use the data tree in the recipe editor to see all available output fields for your specific object and map them to subsequent steps.
Last updated: 11/11/2025, 5:08:44 PM
On this page
