# SAP SuccessFactors LMS - Update object action
The Update object action enables you to update an object in SAP SuccessFactors LMS.
| Input Field | Description |
| Object | Specify the object you plan to create. Fields load dynamically based on the object you select. |
| ID | This is the unique ID assigned to each object, which allows you to update information for a specific object. The label name changes based on the object you select. |
The output fields are determined by the object selected in the input. Map the relevant datapill from the data tree to subsequent steps.
Last updated: 1/19/2026, 4:31:14 PM
