# UKG Pro (Recruiting) - Get record action
The Get record action retrieves the details of a specific record in UKG Pro (Recruiting).
Input field Description
Object Specify the type of object to retrieve details from. Additional fields load dynamically based on the object you select.
ID Enter the unique identifier of the record to retrieve.
The output fields are determined by the object selected in the input. Map the relevant datapill from the data tree to subsequent steps. For example, the Candidate object has the following output schema:
Output field Description
ID The unique ID of a candidate in GUID format.
Creator The creator of a candidate record.
Created at The date and time a candidate was created.
Util person ID The UKG Pro person ID.
EEID The employee identifier.
Preferred_locale The preferred language of the candidate.
Integration user ID The user ID used in 3rd party integrations, such as background check integrations.
Is internal indicator of whether or not a candidate is an internal employee.
Is active indicator of whether or not a candidate is an active employee.
Updated at The date and time a candidate was last updated.
Last updated: 1/2/2026, 5:56:05 PM
On this page
