# Walmart Seller Center - Update record action
The Update record action enables you to update the details of a specific record in the Walmart Seller Center.
| Object | Specify the object you plan to update. Fields load dynamically based on the object you select. |
The output fields are determined by the object selected in the input. Map the relevant datapill from the datatree to subsequent steps.
