# Connect to Coupa
Complete the following steps to connect to Coupa as a data pipeline source. This connection allows the pipeline to extract and sync data from your Coupa instance.
Select Create > Connection.
Search for and select Coupa on the New connection page.
Coupa connection setup
Use the Authentication type drop-down menu to select one of the following authentication types:
- API key
- Client credentials
- Authorization code grant
The required fields vary depending on the authentication type.
Fill in the following fields based on the selected authentication method:
Click Connect to verify and establish the connection.
Last updated: 8/18/2025, 2:14:24 PM
