# How-to Guide - OAuth 2.0 Client Credentials Authentication
The OAuth 2.0 Client Credentials flow is traditionally a way for server to server authentication. This allows you to build a connector that can authenticate as the Workato server which communicates to your target API server.
# Sample Connector - Percolate
title: 'My Percolate connector',
connection: {
fields: [
optional: false,
control_type: 'password',
optional: false,
authorization: {
type: 'custom_auth', #Set to custom_auth
acquire: lambda do |connection|
hash = ("#{connection['client_id']}:#{connection['client_secret']}").base64.gsub("\n", '')
# Token URL
response = post('https://percolate.com/auth/v5/token/').
payload(grant_type: 'client_credentials').
headers(Authorization: "Basic " + hash).
request_format_www_form_urlencoded
access_token: response["access_token"],
refresh_token: response["refresh_token"]
end,
detect_on: [401, 403],
refresh_on: [401, 403],
apply: lambda do |connection|
headers("Authorization": "Bearer #{connection['access_token']}")
end
base_uri: lambda do |connection|
'https://percolate.com'
end
test: lambda do |connection|
get('/api/v5/me')
end,
#More connector code here
- Check out the full connector code here (opens new window)
- Check out the Percolate API (opens new window)
# Step 1 - Defining Connection fields
This component tells Workato what fields to show to a user trying to establish a connection. In the case of Client Credentials Authentication, you would need the Client ID and Client Secret that the user has generated in Percolate.
Information needed | Description |
Client ID | This is the public ID of the OAuth app that should be tied to Workato. This might mean signing Workato up as a verified application in the application |
Client secret | This is the matching private key that the API will verify along with the Client ID. This might mean signing Workato up as a verified application in the application. Never share your client secret with others |
This is done in the fields
key, which accepts an array of hashes. Each hash in this array corresponds to a separate input field.
fields: [
optional: false,
optional: false,
TIP
When defining fields, you need to at least provide the name
key. Additional attributes like optional
, hint
and control_type
allow you to customize other aspects of these fields. For sensitive information like Client Secrets, remember to use the control_type
as password
To know more about how to define input fields in Workato, click here.
# Step 2 - Defining the authorization type
This component tells Workato what type of authentication type this connection should use. This is handled through your type
key in the authorization
object. For Client Credentials authentication, you should use custom_auth
type: 'custom_auth'
# Step 3 - Acquiring the access token
The next step is to define what this connector should do to retrieve an access token. This is done in the acquire
lambda function.
hash = ("client:#{connection['client_id']}:#{connection['client_secret']}").base64.gsub("\n", '')
response = post('https://percolate.com/auth/v5/token/'). # Token URL
end,
In the acquire
key, we pass in the client_id
and client_secret
which were input fields defined in the fields
key. These values are available via the argument to the lambda function - connection
. We pass them as headers and in BASE-64 String encoding. Note that the body of the request must be sent with request_format_www_form_urlencoded
as per Percolates requirements. This request is then sent to Percolate's Token URL.
Upon receiving a the request, the API returns a JSON response.
"access_token": "my-authentication-token",
"token_type": "bearer",
"expires_in": "seconds-until-expiration",
"error": "optional-error-message"
The output of the acquire
lambda function is expected to be an object which is merged into the original connection object. For example:
# Original Connection hash
client_id: "abcd1234",
client_secret: "secretClientSecret"
# After acquire key is executed
client_secret: "secretClientSecret",
access_token: "my-authentication-token"
# Step 4 - Applying the access token to subsequent HTTP requests
Next, you need to tell Workato how to make use of the access token it has retrieved from Percolate. This is done in the apply
key where you can reference the access token now stored in the connection
argument. Any instructions you introduce in the apply
key are subsequently applied to all HTTP requests this connector sends after connection is established.
end
In this example, we have defined the access token (connection['access_token']
) to be added to the headers of any request. For every HTTP request sent, the headers will contain Authorization: Bearer XXX
where XXX
is the access token stored in the connection
hash.
# Step 5 - Defining token refresh behavior
There may be situations in which the API expires the access token after a prescribed amount of time. In these cases, you would need to define refresh_on
signals to let Workato know when to retrieve a new access_token from the OAuth server. refresh_on
accepts an array which may contain HTTP response codes or regex strings.
If an HTTP request in the connector receives any of the HTTP response codes, it will attempt to retrieve a new access token. Likewise, if the contents of the body payload matches any of the defined regex strings, it will retrieve a new access token.
In the example using type: custom_auth
, it will execute the code in the acquire
key.
When the acquire
lambda is run again, this is the expected response from Percolate.
"access_token": "my-NEW-authentication-token",
The expected output of the acquire
lambda function is a hash which is merged into the original connection hash. For example:
# After acquire lambda is executed
access_token: "my-NEW-authentication-token"
# Step 6 - Setting the API's base URI
This component tells Workato what the base URL of the API is. This key is optional but allows you to provide only relative paths in the rest of your connector when defining HTTP requests. Learn how to configure your base_uri
here.
end
TIP
This lambda function also has access to the connection
argument. This is especially useful if the base URI of the API might change based on the user's instance. The connection
argument can be accessed in the following format:
"https://#{connection['domain'].com/api}"
end
# Step 7 - Testing the connection
Now that we have defined the fields we need to collect from an end user and what to do with the inputs from those fields, we now need a way to test this connection. This is handled in the test
key.
test: lambda do
get('/api/v5/me')
end,
In this block, you need to provide an endpoint that allows us to send a sample request using the new credentials we just received. If we receive a 200 OK HTTP response, we show the connection as Successful. In the example above, we are sending a GET
request to the /api/v5/me
endpoint and expecting a 200 response if the API key is valid.
# Connections SDK reference
To be more familiar with the available keys within the connection
key and their parameters, check out our SDK reference.
