# How-to Guide - OAuth 2.0 Authorization Code Variant with Proof Key for Code Exchange (PKCE)
The OAuth 2.0 Authorization code flow is a way for Workato to impersonate a specific user when authenticating to an API. This is done by getting the user's consent via a browser popup when they first attempt to connect. In this variant with PKCE, there is an additional verification step where a challenge is presented in the authorization URL and the verifier is presented in the final token exchange request.
# Sample Connector - Dropbox
  title: "Dropbox pkce",
  connection: {
    fields: [
      { name: 'client_id' },
      { name: 'client_secret' }
    authorization: {
      type: "oauth2",
      client_id: lambda do |connection|
        connection['client_id']
      end,
      client_secret: lambda do |connection|
        connection['client_secret']
      end,
      pkce: lambda do |verifier, challenge|
          verifier: verifier,
          challenge: challenge,
          challenge_method: "S256"
      end,
      authorization_url: lambda do |connection|
        "https://www.dropbox.com/oauth2/authorize?client_id=#{connection['client_id']}&response_type=code"
      end,
      token_url: lambda do |_connection|
        "https://api.dropbox.com/oauth2/token"
      end,
      apply: lambda do |_connection, access_token|
        headers('Authorization': "Bearer #{access_token}")
      end
  test: lambda do |_connection|
    post("https://api.dropboxapi.com/2/check/app", {})
  end,
  #More connector code here
# Step 1 - Defining connection fields
This component tells Workato what fields to show to a user trying to establish a connection. In the case of authentication code grant with PKCE, you would need the Client ID and Client Secret that the user has generated in Dropbox's developer console.
This is done in the fields key, which accepts an array of hashes. Each hash in this array corresponds to a separate input field.
    fields: [
        optional: false
        optional: false,
        control_type: 'password'
TIP
When defining fields, you need to at least provide the name key. Additional attributes like optional, hint and control_type allow you to customize other aspects of these fields. For sensitive information like Client Secrets, remember to use the control_type as password.
Learn more about how to define input fields in Workato.
# Step 2 - Defining the authorization type
This component instructs Workato what to do with the values received from the input fields to establish a connection. This is handled through your authorization key. In this key, you begin by first defining the type of authorization. In this case, you should use oauth2, similar to the Authorization Code Grant flow.
      type: "oauth2",
# Step 3 - Defining the Client ID, Client Secret and PKCE parameters
These components tell the SDK framework what to use for the client ID, client secret and PKCE parameters later on.
      end,
      end,
          verifier: verifier,
      end,
In our example, we simple map the user's inputs for the client ID and secret to the relevant client_id and client_secret lambdas respectively. This is done with the connection argument which is a hash representing the user's inputs in the fields defined earlier.
Next, you'll also need to define the pkce lambda, which is an important marker that signifies that this is an Authorization Code Grant Flow with PKCE. Within this lambda, you will receive 2 arguments which correspond to the verifier and challenge. You may simple use both of these arguments as-is and pass them as the output of the pkce lambda as seen in the example.
# Step 4 - Defining authorization url, and token url
With the PKCE variant of OAuth 2, you supply 2 the authorization url and the token url - similar to the normal auth code grant flow.
  • The authorization url - where we will redirect the user via a browser popup to provide authorization.
  • The token url - where this connector will send a request to receive an access token after receiving an auth code from the authorization url
    "https://www.dropbox.com/oauth2/authorize"
  end,
  token_url: lambda do |connection|
  end,
When defining the authorization_url lambda function, Workato automatically passes the following parameters:
  • client ID
  • redirect URI
  • code challenge
  • state
In some cases, you may have to add scope to the URL as needed. If the application requires that you register the redirect URI beforehand, use the following URL: https://www.workato.com/oauth/callback.
When defining the token_url lambda function, Workato automatically passes the following parameters:
  • client ID
  • client secret
  • code verifier
  • grant_type
For the token_url request, we follow RFC standards and use a POST request with the relevant information in the payload body. When Workato exchanges the short-lived authorization code for a longer-living access token, we expect the response from the token_url endpoint to contain 2 main values - access_token and refresh_token. Here is a sample response:
  "access_token": "my-authentication-token",
  "token_type": "bearer",
  "expires_in": "seconds-until-expiration",
  "refresh_token": "my-refresh-token",
  "error": "optional-error-message",
  "ref":
    "type": "user",
    "id": USER_ID
The authentication stores the values associated with access_token and refresh_token.
# Step 5 - Applying the access token to subsequent HTTP requests
In the apply key, we apply the acquired access token as a header input.
We can retrieve the access_token by referencing simply passing in access_token as a parameter into the apply key. This argument access_token is automatically assigned from the output of the token_url lambda function.
    apply: lambda do |connection, access_token|
      headers("Authorization": "OAuth2 #{access_token}")
    end,
To learn more about the available parameters and keys in the connection object, see SDK Reference - connection.
# Step 6 - Defining token refresh behavior
In most cases, OAuth 2.0 Authentication has both short-lived access tokens and long-lived refresh tokens. Sometimes, refresh tokens never expire.
WARNING
Note that not all APIs issue refresh token credentials. Check with the API about this requirement.
When the access-token expires, you can define the behavior that your connector should take to refresh the access token using the refresh token.
    refresh_on: [401, 403],
    refresh: lambda do |connection, refresh_token|
      response = post("https://api.dropbox.com/oauth2/token").
                    payload(
                      grant_type: "refresh_token",
                      client_id: connection["client_id"],
                      client_secret: connection["client_secret"],
                      refresh_token: refresh_token,
                      redirect_uri: 'https://www.workato.com/oauth/callback'
          access_token: response["access_token"],
          refresh_token: response["refresh_token"]
    end,
To refresh your access token, you have to use two keys in the authorization key - refresh_on and refresh. refresh_on accepts an array that may contain HTTP response codes or regex strings. If an HTTP request in the connector receives any of the HTTP response codes, or if the body of the payload matches a regex string, it will execute the code in the refresh key to attempt to retrieve a new access token.
In the refresh key, you have access to an argument that represents the refresh_token received from the initial token request. The expected output of this lambda function is an array where the first index is a hash denoting the new access_token as well as the new refresh_token if applicable. These will be used to update the initial values for a long lasting connection.
To learn more about the refresh lambda, see SDK Reference - authorization.
# Step 7 - Setting the API's base URI
This component tells Workato what the base URL of the API is. This key is optional but allows you to provide only relative paths in the rest of your connector when defining HTTP requests. Learn how to configure your base URI.
    base_uri: lambda do |connection|
      'https://api.dropboxapi.com'
    end
TIP
This lambda function also has access to the connection argument. This is especially useful if the base URI of the API might change based on the user's instance. The connection argument can be accessed in the following format:
      "https://#{connection['domain'].com/api}"
    end
# Step 8 - Testing the connection
Now that we have defined the fields we need to collect from an end user and what to do with the inputs from those fields, we now need a way to test this connection. This is handled in the test key.
    test: lambda do
    end,
In this block, you need to provide an endpoint that allows us to send a sample request using the new credentials we just received. If we receive a 200 OK HTTP response, we show the connection as Successful. In the example above, we are sending a POST request to the /2/check/app endpoint and expecting a 200 response if the access token we just received is valid.
# Auth code grant PKCE variation
In some cases, you may need to use the acquire lambda to complete the token request. Here we have an example with the same Dropbox connection, except using the acquire lambda.
  connection: {
    fields: [
    authorization: {
      type: "oauth2",
      end,
      end,
          verifier: verifier,
      end,
      end,
      acquire: lambda do |connection, auth_code, redirect_uri, verifier|
        response = post("https://api.dropbox.com/oauth2/token",
          grant_type: "authorization_code",
          code: auth_code,
          redirect_uri: redirect_uri,
          code_verifier: verifier,
        ).request_format_www_form_urlencoded
            refresh_token: response["refresh_token"],
            refresh_token_expires_in: response["expires_in"] # Expiration time of the refresh token from now in seconds
          nil,
          { instance_id: nil }
      end,
      end
Take note that you receive an additional argument, verifier in the acquire lambda which corresponds to the same verifier you passed as the output of the pkce lambda.
# Connections SDK reference
To be more familiar with the available keys within the connection key and their parameters, check out our SDK reference.
Last updated: 2/27/2026, 9:05:55 PM
