# Handling XML
XML (eXtensible Markup Language) is a widely used format for structured data. It stores and exchanges information using a nested element structure with tags and attributes. XML is common in APIs, enterprise integrations, and document-based data exchange.
Some integrations provide XML files or embed XML in multi-format payloads. You can use Workato to extract structured values from this content, transform the structure, validate it against a schema, or generate new XML during recipe execution.
# XML tools by Workato
Use XML tools by Workato when you need to parse, transform, validate, or generate XML content. You can process XML files from Dropbox, SFTP, or Google Drive, or handle XML content from any step that outputs file content.
Last updated: 8/14/2025, 5:07:56 PM
