# List and hash formulas FAQs
Get answers to frequently asked list and hash formula questions.
How are lists used in Workato?
A list in Workato is an ordered, integer-indexed collection of objects, similar to arrays in other programming languages.
How do you access items inside a list in Workato?
You can access items in a list using indexing, starting at 0. For example, number_list[0]
would access the first line item.
Does Workato support negative indexes for lists?
Yes, Workato supports negative indexes for lists. For example, number_list[-1]
would access the last item in a list.
What do the first and last formulas do?
The first
formula returns the first item in a list. The last
formula returns the last item in a list.
What is a hash, and how does it differ from a list?
A hash in Workato is a collection of unique keys and their corresponding values. Unlike lists, hashes allow you to use any object type as keys.
How are lists of hashes used?
Lists of hashes represent complex data structures where each item in the list is a hash with multiple key-value pairs. Lists of hashes are often used for organizing and processing structured data.
How do you access values in a hash?
You can access values in a hash using the keys. For example, line_item["item_name"]
accesses the value associated with the item_name
key.
Is there a direct union (&) operand for combining lists in Workato?
Workato doesn't support a direct union (&) operand. To achieve a similar result, you can combine lists using the concat
formula and then remove duplicates with the uniq
formula. Learn how.
How can you find the difference between two lists?
To find the difference between two lists, you can use the subtraction (-) operand. For example, list - updated_list
returns the items present in list
but not in updated_list
