Agent Studio use cases
Agent Studio enables you to use AI-powered agents known as genies that can talk to people, understand what users need, and then perform actions, such as fetch information, run automations, or complete tasks. A genie takes action unlike a typical chatbot that simply provides answers.
Agent Studio use cases provide steps on how perform the following actions:
- Create a genie
- Create and connect a knowledge base
- Create a knowledge base recipe
- Create a skill
- Add Agent orchestration to your workflow
- Upload files and images to your genie
Use cases are intended to serve as examples. Agent Studio modifications, such as triggers, actions, knowledge base configuration, and skills may require adjustments for your specific setup.
Connect your Confluence account to your genie knowledge base
This use case enables you to connect a knowledge base to Confluence with knowledge base recipe that scans for pages periodically and automatically syncs and updates available information.
Configure a skill to send Slack messages
This use case enables you to configure a skill that sends Slack messages from your genie's AI model.
Upload files and images for Coupa verification
This use case enables you to upload and verify files and images, such as itemized recipes, before you submit expenses to Coupa.
Build a personal assistant genie with Telegram
This use case enables you to build a personal assistant genie in Telegram using Agent orchestration.
Process purchase orders with a procurement genie
This use case enables you to configure a procurement genie that uses a decision model to apply deterministic fulfillment rules to purchase order requests.
Route requests across agents with a decision model
This use case enables you to build a front-facing genie that uses a decision model to route user requests to the correct specialist genie.
More resources
