# Update request action
Update a request in a Workflow app. You must specify the values of all request fields you plan to update.
# Input fields
Workflow app
Select a Workflow app in which to update the request.
Record ID
Choose a request (identified by its Record ID) to update. Use a datapill or enter the exact ID. Workato automatically generates a unique ID for each record in a Workflow app's corresponding data table. Workato requires the Record ID to perform certain Workflow apps connector actions, including update record, and delete record actions.
Update request fields for the specified request
Fill in the fields for the specified request. You must fill in the fields you plan to update. Fields that are not specified are not updated. The fields that appear here depend on the request you plan to update.
Output is dynamic and may vary depending on the actions and triggers in your recipe, as well as the columns present in your Workflow app's corresponding data table.
To use this data in downstream steps, map in the relevant datapill from the datatree.
- Request
- This JSON object includes the following available attributes. Additional output is available depending on the Workflow app you select and its data table.
- Record ID
- Workato automatically generates a unique ID for each record in a Workflow app's corresponding data table.
- Active task
- A nested JSON object within the Request object.
- This object is empty if there is not an active task associated with the request.
Available attributes include
- Task ID:
- The ID of the task.
- Task name:
- The name of the task.
- Status:
- The task's status.
- Assigned user:
- A nested JSON object within the Assigned task object.
- This object is empty if the task is assigned to a group.
- User ID:
- The ID of the user assigned to the task.
- User name:
- The name of the user assigned to the task.
- Email:
- The email of the user assigned to the task.
- Status:
- The status of the user assigned to the task.
- Assigned group:
- This object is empty if the task is assigned to an individual user.
- User ID:
- User name:
- Status
- Due date:
- The due date of the task.
- Task URL:
- The URL for the task.
- Created by
- User ID:
- The ID of the user who created the request.
- User name:
- The name of the user who created the request.
- Email:
- The email of the user who created the request.
- Status:
- The status of the user.
- Groups
- A nested JSON object within the Created by object.
- Group ID:
- The ID of the group this task is assigned to.
- Group name:
- The name of the group this task is assigned to.
- List size
- List index
- Stage
- Stage ID:
- Group name:
- Created at
- The date the record was created.
- Updated at
- The date the record was most recently updated.
