# Change workflow stage action
Change workflow stage is an action you can use to transition a request in a Workflow app through the workflow.
Typical use cases for this action include the following scenarios:
- If the input provided does not pass validation, mark the request as Invalid.
- If the request does not need user approval, mark it as Done automatically.
- If the manager approval task is approved, mark the request as Completed.
# Input fields
Workflow app
Select an App from the list of available Apps.
Record ID
The ID of the record whose workflow stage you plan to change. You can map this in using a datapill from a trigger or action from the Workato Data Tables or Workflow apps connector.
Workflow stage
The new workflow stage for the record. Select one of the stages defined in your application settings.
