# Configure Marketo as your data pipeline source
Set up Marketo as a data pipeline source to extract and sync records into your destination. This guide includes connection setup, pipeline configuration, and key behavior for working with Marketo as a source.
Workato uses the Marketo REST API to extract object data for pipeline syncs.
# Features supported
The following features are supported when using Marketo as a data pipeline source:
  • Extract data using the Marketo REST API
  • Support for full and incremental sync
  • Field-level selection for object extraction
  • Schema drift detection and handling
  • Field-level data masking
# Prerequisites
  • A custom service registered in your Marketo Admin console
  • The REST API endpoint for your Marketo instance
  • Client ID and client secret from the custom service
  • Read access to the objects used in the pipeline
# How to connect
Complete the following steps to connect to Marketo as a data pipeline source. This connection allows the pipeline to extract and sync data from your Marketo instance.
Connect to Marketo
Select Create > Connection.
Search for and select Marketo on the New connection page.
Marketo connection setupMarketo connection setup
Enter the REST Endpoint. This URL must match your Marketo instance’s Admin/Web Services REST API endpoint.
Enter the Custom Service client ID associated with your Marketo custom service. Refer to the Marketo Engage Developer Documentation (opens new window) to create a custom service in Marketo.
Enter the Custom Service client secret for the Marketo client ID.
Click Connect to verify and establish the connection.
# Configure the pipeline
Complete the following steps to configure Marketo as your data pipeline source:
Select Create > Data pipeline.
Select Start building.
Select Marketo from Your Connected Source Apps.
Choose the Marketo connection you plan to use for this pipeline. Alternatively, click + New connection to create a new connection.
Choose a Marketo connectionChoose a Marketo connection
Click Add object to open the object wizard.
Add objectAdd object
Search or browse the list of available Marketo objects. Select the objects you plan to sync and click Add.
Select objectsSelect objects
Expand objectExpand object
You can expand any object to view its fields. Keep all fields selected to extract all available data, or deselect specific fields to exclude them from data extraction and schema replication.
Click Add object again to add more objects using the same flow. You can repeat this step to include multiple Marketo objects in your pipeline.
12
13
# Supported Marketo objects
The connector supports common Marketo objects, including Leads, Activities, and Programs. Workato uses the Marketo REST API to query and extract records.
Last updated: 3/19/2026, 5:30:39 PM
