# Configure a data pipeline
This guide provides the required steps to configure a data pipeline.
# Prerequisites
Ensure you have the following before you create a data pipeline:
- Source application: Salesforce, NetSuite2, Jira, Coupa, or Marketo
- Destination data warehouse: Snowflake or Databricks
Refer to the Connect to sources and destinations guide for more information about data pipeline sources and destinations.
# Configure your data pipeline source application
Complete the following steps to configure a data pipeline based on the source application you plan to use:
# Configure Salesforce as your data pipeline source
Select Create > Data pipeline.
Provide a Name for the data pipeline.
Data pipeline setup
Click Start building.
Select Salesforce from Your Connected Source Apps.
Choose the Salesforce connection you plan to use for this pipeline. Alternatively, click + New connection to create a new connection. Refer to the Connect to Salesforce guide for more information.
Choose a Salesforce connection
Select the Objects you plan to use in your pipeline. The pipeline loads a list of available Salesforce objects, which allows you to:
- Search for specific objects.
- Expand objects to view related fields.
- Select multiple objects to sync.
Select objects to sync
Expand object
You can expand any object to view its fields. Keep all fields selected to extract all available data, or deselect specific fields to exclude them from data extraction and schema replication.
- Select Auto-sync new fields to detect and apply schema changes automatically.
- Select Block new fields to manage schema changes manually. This option may cause the destination to fall out of sync if the source schema updates.
Complete the following steps in the Frequency field to specify how often the pipeline syncs data to the destination:
Select the Time unit, such as Minutes, Hours, or Days.
Specify the sync interval in the Trigger every field.
For example, if you select Hours as the Time unit and enter 12 in the Trigger every field, the pipeline syncs every 12 hours. The minimum interval you can set is 30 minutes.
Configure sync frequency
Select a start date for the historical data sync in the When first started, this pipeline should pick up records from field. This defines the earliest date from which the pipeline extracts records. If you leave this field blank, the pipeline picks up all available records from the source.
You can't change this value after you run the pipeline. Refer to the When first started, this recipe should pick up events from section for more information.
Click Save to save your progress before you configure your data pipeline destination.
# Configure NetSuite2 as your data pipeline source
ENABLE SUITEANALYTICS CONNECT
Ensure that the SuiteAnalytics Connect feature is enabled in your NetSuite account before you use NetSuite2 as a source. This feature allows the pipeline to access NetSuite data through the SuiteAnalytics framework.
Refer to NetSuite documentation (opens new window) for details on enabling this feature.
Data pipeline setup
Select NetSuite2 from Your Connected Source Apps.
Choose the NetSuite2 connection you plan to use for this pipeline. Alternatively, click + New connection to create a new connection. Refer to the Connect to NetSuite2 guide for more information.
Choose a NetSuite2 connection
Expand object
# Configure Marketo as your data pipeline source
Data pipeline setup
Select Start building.
Select Marketo from Your Connected Source Apps.
Choose the Marketo connection you plan to use for this pipeline. Alternatively, click + New connection to create a new connection. Refer to the Connect to Marketo guide for more information.
Choose a Marketo connection
Expand object
For example, if you select hours as the Time unit and enter 12 in the Trigger every field, the pipeline syncs every 12 hours. The minimum interval you can set is 30 minutes.
# Configure Jira as your data pipeline source
Data pipeline setup
Select Jira from Your Connected Source Apps.
Choose the Jira connection you plan to use for this pipeline. Alternatively, click + New connection to create a new connection. Refer to the Connect to Jira guide for more information.
Choose a Jira connection
Expand object
# Configure Coupa as your data pipeline source
Data pipeline setup
Select Coupa from Your Connected Source Apps.
Choose the Coupa connection you plan to use for this pipeline. Alternatively, click + New connection to create a new connection. Refer to the Connect to Coupa guide for more information.
Choose a Coupa connection
Expand object
# Configure your data pipeline destination
Complete the following steps based on the destination you plan to use:
# Configure Snowflake as your pipeline destination
Before you start the pipeline, ensure the schema in Snowflake is newly created and empty. This prevents errors during the initial sync and ensures the pipeline can create destination tables without conflicts.
Click the Load data to target table in destination app action. This action defines how the pipeline replicates data in the destination.
Configure the Load data to target table in destination app action
Select Snowflake in the Your Connected Destination App field.
Choose the Snowflake connection you plan to use for this pipeline. Alternatively, click + New connection to create a new connection. Refer to the Connect to a Snowflake destination guide for more information.
Choose a Snowflake connection
The Load data to target table in destination app action automatically replicates the object schema from the source to Snowflake. Explicit field mapping isn't required.
Workato pipelines automatically create destination tables based on the source schema. The pipeline also creates a stage and temporary tables to support data replication and update operations.
Select Save to save the pipeline.
# Configure Databricks as your pipeline destination
Ensure the schema in Databricks is newly created and empty before you start the pipeline. This prevents errors during the initial sync and allows the pipeline to create destination tables without conflicts.
Select Databricks in the Your Connected Destination App field.
Choose the Databricks connection you plan to use for this pipeline. Alternatively, click + New connection to create a new connection. Refer to the Connect to a Databricks destination guide for more information.
Choose a Databricks connection
The Load data to target table in destination app action automatically replicates the object schema from the source to Databricks. Explicit field mapping isn't required.
# Start your data pipeline
Select Start pipeline to start the data pipeline. After you start the pipeline, it syncs selected objects and loads historical data.
You can also choose to Move, Edit, or Apply tags to the pipeline.
Refer to the Monitor data pipeline recipes guide to learn how to monitor pipeline activity and troubleshoot issues.
Last updated: 11/7/2025, 9:04:29 PM
