# Configure Coupa as your data pipeline source
Set up Coupa as a data pipeline source to extract and sync records into your destination. This guide includes connection setup, pipeline configuration, and key behavior for working with Coupa as a source.
# Features supported
The following features are supported when using Coupa as a data pipeline source:
- Extract data using the Coupa REST API
- Support for full and incremental sync
- Field-level selection for object extraction
- Schema drift detection and handling
- Field-level data masking
# Prerequisites
- A Coupa instance with API access enabled
- Coupa instance URL
- Required scopes for the API
- Read access to the objects you plan to sync
# How to connect
Complete the following steps to connect to Coupa as a data pipeline source. This connection allows the pipeline to extract and sync data from your Coupa instance:
Select Create > Connection.
Search for and select Coupa on the New connection page.
Coupa connection setup
Use the Authentication type drop-down menu to select one of the following authentication types:
- API key
- Client credentials
- Authorization code grant
The required fields vary depending on the authentication type.
Fill in the following fields based on the selected authentication method:
Click Connect to verify and establish the connection.
# Configure the pipeline
Complete the following steps to configure Coupa as your data pipeline source:
Select Create > Data pipeline.
Data pipeline setup
Select Start building.
Select Coupa from Your Connected Source Apps.
Choose the Coupa connection you plan to use for this pipeline. Alternatively, click + New connection to create a new connection.
Choose a Coupa connection
Click Add object to open the object wizard.
Add objects
Search or browse the list of available Coupa objects. Select the objects you plan to sync and click Add.
Select objects
Expand object
Expand any object to view its fields. Keep all fields selected to extract all available data, or deselect specific fields to exclude them from data extraction and schema replication.
Optional. Configure field-level data protection. After you expand an object, choose how to handle each field:
- Replicate as is (default): Data values at the source are replicated identically to the destination.
- Hash: Hash sensitive data values in the column before syncing to your destination.
Click Add object again to add more objects using the same flow. You can repeat this step to include multiple Coupa objects in your pipeline.
- Select Auto-sync new fields to detect and apply schema changes automatically.
- Select Block new fields to manage schema changes manually. This option may cause the destination to fall out of sync if the source schema updates.
# Supported Coupa objects
The Coupa connector uses the Coupa REST API to retrieve records for pipeline sync. It supports standard objects commonly used in Coupa environments, including accounts, approvals, and contracts.
Last updated: 3/19/2026, 5:30:39 PM
Configure sync frequency
