HTTP connector - New event via polling trigger ​
The New event via polling trigger fetches events at each polling interval. Workato makes a GET request to the URL you provide. The number of events retrieved for each poll depends on the API endpoint that you send the request to.
You must create an HTTP connection before you can configure an HTTP trigger.
REAL-TIME TRIGGER
You can use the New event via webhook trigger if your use case requires your recipe to respond to trigger events in real-time.
PAGINATION NOT SUPPORTED
This trigger only reads the first page of records in APIs that enforce pagination. You can set up a trigger with the connector SDK if your use case expects a paginated response.
Input ​
New Event via PollingNew Event via Polling
Input fieldDescription
Event nameThe name for this polled event.
URLThe HTTP endpoint that you are connecting to.
Request headersProvide the HTTP request headers, if applicable.
Response content typeSelect the expected response data type.
Response body exampleProvide a sample of the response body. Ensure that this example follows the content type indicated. Please find valid sample payloads in the section below.
Trigger poll intervalSelect how frequent to check for new events. Refer to Polling intervals for more information.
Response body example ​
JSON ​
For JSON responses, please enclose the sample payload with square brackets. For example:
json
    "fullName": "John Doe",
    "firstName": "John",
    "lastName": "Doe"
    "company": "Workato",
    "legalName": "Workato Inc",
    "domain": "workato.com"
XML ​
The outermost tag should use the array type for XML responses. For example:
xml
<roles type="array">
<role>
		<id.w_a-b type="integer">3</id.w_a-b>
		<name>User</name>
		<description>Standard role</description>
		<omnipotent type="boolean">false</omnipotent>
		<system-role type="boolean">true</system-role>
		<updated-by>
			<id.w_a-b type="integer">1</id.w_a-b>
			<login>sampleaccount</login>
			<email>[email protected]</email>
			<employee-number />
			<firstname>Company</firstname>
			<lastname>X</lastname>
			<salesforce-id.w_a-b nil="true" />
			<avatar-thumb-url nil="true" />
			<custom-field-8 />
			<custom-field-7 />
			<gpo-entity />
			<radio-button-test />
			<subsidary />
			<function />
			<seg3default />
			<username1 />
		</updated-by>
	</role>
</roles>
Output ​
The output of this trigger depends on the response schema provided.
More resources ​
