# Chat interface
The chat interface is the genie component visibly exposed to your end users. You can integrate the chat interface into platforms where your organization works, such as Slack, Microsoft Teams, Workato GO, and internal systems with custom chatbots. The chat interface includes the following capabilities:
  • A user-friendly interface for employees to interact with the genie
  • Multiple communication channels to fit your organization's workflow
  • Customizable UI elements to match your brand and user experience preferences
  • Real-time communication between users and the genie
CHAT INTERFACE CONFIGURATION
The genies feature can only be configured to use Slack, Microsoft Teams, or Workato GO as the chat interface. Support for additional chat interface apps is in development.
# Getting started with a chat interface
Refer to Create a genie manually for complete steps on how to create a genie with a job description, AI model, chat interface, knowledge base, knowledge base recipe, and skills.
Complete the following steps to create a genie and configure its chat interface:
Sign in to Workato.
Go to AI Hub > Genies and click + Create genie. Alternatively, you can create a genie from the Projects page by clicking Create > Genie or pressing C+G.
Select New genie to create a blank genie.
Use the Location drop-down menu to select a location for your genie.
Enter a request or goal for your genie in the What would you like your genie to help with? field.
Create a genieCreate a genie
Click Start building. The genie Build page displays.
JOB DESCRIPTIONS ARE AUTOMATICALLY GENERATED
The Job description is automatically generated based on the input you provide to the What would you like your genie to help with? field during genie setup and can be edited to suit your requirements.
Genie build pageGenie build page
Go to the genie where you plan to add the chat interface.
Click Edit.
Click Chat interface to open the configuration page.
Select your chat interfaceSelect your chat interface
Select the app to use as your interface:
Last updated: 3/19/2026, 4:35:07 PM
