Remote MCP servers ​
Remote Model Context Protocol (MCP) servers are hosted externally and accessed by AI assistants over the network instead of running tools and integrations locally. This means a single MCP server can serve multiple users and multiple AI platforms, such as Claude, ChatGPT, Microsoft Copilot, or Cursor. You can update and maintain remote MCP servers centrally without requiring changes to your client configurations.
FEATURE AVAILABILITY
MCP is available to all users in the US, EU, AU, JP, SG, IL, KR, and UK data centers. MCP servers are hosted in the US, EU, and APAC regions and respect data residency requirements where possible. MCP isn't available to workspaces in the CN data center. This reflects local regulatory requirements and Workato's commitment to data sovereignty and applies to our multi-tenant and Virtual Private Workato (VPW) offerings.
Contact your Customer Success representative if you're interested in using MCP or require additional information.
Install remote MCP servers ​
You can install a remote MCP with a URL that authenticates with a token or through Workato Identity after you create an MCP server. The configurations in this section use Cursor and Claude Desktop.
NEED AN EXAMPLE?
Review the LLM, GitHub, and Workato Developer API use case for steps to create an MCP server integration that lets you create GitHub issues with natural-language commands in ChatGPT, Claude, or Cursor.
Complete the following steps to install the MCP remote server with a URL:
Sign in to Workato.
Configure your MCP integration:
Add a remote MCP server to an AI model ​
You can use your REMOTE_MCP_URL to configure your remote server with the following AI models:
ChatGPT MCP configuration ​
Complete the following steps to add your MCP server to ChatGPT:
Go to your ChatGPT account.
Go to Settings > Apps & Connectors > Advanced settings and enable the Developer mode toggle.
Go to Settings > Apps & Connectors.
Click Create. This button is only visible when the Developer mode toggle is enabled.
Enter a name for your MCP connector in the Name field.
ChatGPT connectorConfigure your ChatGPT MCP connector
Paste your MCP URL and token in the URL field.
Optional. Enter a description in the Description field.
Use the Authentication drop-down menu to select No Auth.
Select the checkbox to accept the risk of adding a custom MCP server.
Click Create.
Create a new chat in ChatGPT to use your MCP tools.
Refer to ChatGPT MCP server publication to share your MCP server with your AI model organization.
Claude MCP configuration ​
Complete the following steps to add your MCP server to Claude:
Sign in to Workato.
Go to AI Hub > Enterprise MCP > Custom servers.
Select the MCP server and copy the Remote MCP URL.
Go to your Claude account.
Go to Settings > Connectors.
Click + Add new connector.
Claude connectorConfigure your Claude MCP connector
Paste your MCP URL and token into the Remote MCP server URL field.
Click Add. The newly created MCP connector appears in the list of connectors.
Click Configure.
Use the permissions drop-down menu to select Always ask permission or Allow unsupervised. Always ask permission is selected by default.
12
Create a new chat in Claude to use your MCP tools.
Refer to Claude MCP server publication to share your MCP server with your AI model organization.
Cursor MCP configuration ​
The following process authenticates with an MCP URL and authentication token. Refer to Cursor MCP remote server configuration with Workato Identity authentication if you plan to authenticate with Workato Identity.
Complete the following steps to add your MCP server to Cursor:
Go to Settings > Cursor settings.
Click MCP & Integrations in the sidebar.
Click + New MCP Server to open the mcp.json file.
New MCP serverClick + New MCP Server
Update the configuration to use the MCP URL and token you copied in the preceding steps. For example:
json
  "mcpServers": {
    "snowflake-tools": {
      "url": "https://2255.apim.mcp.workato.com?wkt_token=YOUR_API_TOKEN"
    "github-tools": {
      "url": "https://387.apim.mcp.workato.com/abc247/example-collection-name-v1?wkt_token=YOUR_API_TOKEN"
Save your changes.
Create a new chat with your Cursor agent to use your MCP tools.
You must start a new chat with your agent. Cursor agents only have access to the tools and capabilities available when a chat begins. Agents can't detect or use new MCP configurations, servers, or tools added after starting a chat.
Refer to Cursor MCP server publication to share your MCP server with your AI model organization.
Gemini Enterprise MCP configuration with Workato Identity authentication ​
Gemini Enterprise asks you to enter a Client ID, Client Secret, and Scopes on its own OAuth setup screen. Workato Identity issues these values through Dynamic Client Registration (DCR) when you send a registration request.
Ensure the following before you begin:
Each registration request creates a new Client ID and Client Secret pair. You receive both values from the registration response, not from Workspace admin > API clients.
Complete the following steps to add your MCP server to Gemini Enterprise:
Go to the Details tab of your MCP server and copy the Remote MCP URL.
Details tab showing Workato Identity as the authentication method and the Remote MCP URL with a Copy button.Remote MCP URL on the MCP server Details tab
Open MCP_SERVER_URL/.well-known/oauth-protected-resource in a browser, replacing MCP_SERVER_URL with the Remote MCP URL you copied.
Copy the authorization server URL from the authorization_servers array, without the brackets or quotation marks.
Open AUTHORIZATION_SERVER_URL/.well-known/oauth-authorization-server in a browser. Replace AUTHORIZATION_SERVER_URL with the value from the previous step. The page that opens is the OAuth discovery document. Copy the following values:
  • registration_endpoint
  • authorization_endpoint
  • token_endpoint
  • scopes_supported
Run the following command in a terminal, replacing the following placeholders:
  • REGISTRATION_ENDPOINT: the registration_endpoint value from the discovery document.
  • REDIRECT_URI: the redirect URI that the external MCP client provides. Use https://vertexaisearch.cloud.google.com/oauth-redirect for Gemini Enterprise.
  • CLIENT_NAME: a name for the client.
  • SCOPES: a space-separated list of values from scopes_supported. Commas aren't valid.
shell
curl -X POST "REGISTRATION_ENDPOINT" \
  -d '{
    "client_name": "CLIENT_NAME",
    "redirect_uris": ["REDIRECT_URI"],
    "grant_types": ["authorization_code", "refresh_token"],
    "response_types": ["code"],
    "token_endpoint_auth_method": "client_secret_post",
    "scope": "SCOPES"
Copy client_id, client_secret, and scope from the JSON response. The server can add scopes beyond those you requested.
Example response
json
  "client_id": "CLIENT_ID",
  "client_id_issued_at": 1700000000,
  "client_secret_expires_at": 0,
  "scope": "openid profile email claudeai",
  "client_secret": "CLIENT_SECRET"
Enter the following values in the external MCP client. The field names match Gemini Enterprise and might differ in other MCP clients.
FieldValue
MCP Server URLThe Remote MCP URL from the Details tab of your MCP server
Authorization URLauthorization_endpoint from the discovery document
Token URLtoken_endpoint from the discovery document
Client IDclient_id from the registration response
Client Secretclient_secret from the registration response
Scopesscope from the registration response
Refer to Create the custom MCP server data store in the Google Cloud documentation for where to enter these values in Gemini Enterprise.
Microsoft Copilot MCP configuration ​
Microsoft Copilot supports OAuth authentication and API-based access for MCP servers. Refer to the Microsoft Copilot MCP server configuration documentation for more information.
Complete the following steps to add your MCP server to Microsoft Copilot:
Sign in to your Microsoft Copilot Studio account.
Select Agent in the sidebar and create a new agent.
Provide a name for your agent in the Name field.
Optional. Provide a description for your agent in the Description field.
Add your MCP server as a tool. Steps for adding an MCP server vary based on your authentication method:
Return to Microsoft Copilot Studio and connect to the newly created MCP server.
Refer to Microsoft Copilot MCP server publication to share your MCP server with your AI model organization.
