# Connector overview
The SQL Transformations connector has the following single action:
# Query CSV data action
The Query CSV data action allows users to:
  • Connect multiple different types of CSV data sources together.
  • Run transformational queries on the data sources and extract the CSV output.
  • Set the format of CSV data output coming from the action.
To use this connector, read the following guides to learn how to configure the required input fields:
  1. Set up your data source
  2. Set up your query
  3. Configure your output
  4. Output fields
Sample use cases
See our guides for step-by-step instructions on how to leverage SQL Transformations for the following use cases:
Last updated: 2/28/2023, 5:07:04 PM
