# Okta End User MCP server
The Okta End User MCP server enables LLMs to understand and retrieve your identity, access, and authentication information in Okta through natural conversation. The Okta End User MCP server helps you understand your identity profile, discover which applications you have access to, and quickly launch applications with SSO links directly from your AI conversation.
# Uses
Use the Okta End User MCP server when you plan to perform the following actions:
- View your own Okta profile information including role, department, and manager
- Discover which applications you currently have access to
- Get direct SSO links to launch applications without navigating Okta
- Understand your organizational context and reporting relationships
- Check your profile attributes and identity information
# Example prompts
Use the following example prompts to invoke Okta End User MCP server tools:
What's my job title and department in Okta?Who is my manager?What applications do I have access to?Show me my Okta profile information.Get me the SSO link to launch Salesforce.What apps can I access?
# Okta End User MCP server tools
The Okta End User MCP server provides the following tools:
| Tool | Description |
| get_my_user_profile | Retrieves profile and organizational information for the authenticated user. |
| list_assigned_applications | Retrieves the set of applications currently assigned to the authenticated user. |
| get_application_sso_link | Retrieves the single sign-on (SSO) link for an application assigned to the authenticated user. |
# Install the Okta End User MCP server
Go to AI Hub > MCP servers.
Click + Create MCP server.
Go to the Start with a template section and select the prebuilt MCP server you plan to use.
Click Use this template.
Provide a name for your MCP server in the MCP server name field.
- User's connection: MCP server tools perform actions based on the identity and permissions of the user who connects to the application. Users authenticate with their own credentials to execute the skill.
- Your connection: This option uses the connection established by the recipe builder and follows the same principles as normal app connections.
Select your connection type
# Okta connection setup
View Okta connection setup steps
Okta supports the following authentication types:
- Authorization code grant authentication (OAuth 2.0)
- Client credentials-based authentication (OAuth 2.0)
- API key-based authentication
Workato recommends using either authorization code grant authentication (OAuth 2.0) or client credentials-based authentication (OAuth 2.0) for improved security in your connection. These methods also let you define granular permissions that control which resources Workato can access in Okta.
VIRTUAL PRIVATE WORKATO (VPW) CUSTOMERS
This feature requires configuration steps that are specific to your Virtual Private Workato (VPW) instance. If you are a VPW customer, refer to your VPW private documentation for the configuration details for your instances.
# Authorization code grant authentication
Authorization code grant authentication requires creating an app integration and secret in Okta.
View authorization code grant connection setup steps
# Minimum and default scopes
OAuth 2.0 scopes define the level of access Workato has to your Okta instance. Review the following sections to determine which scopes to assign to your app integration for OAuth 2.0 authorization code grant authentication.
View minimum scopes
The Okta connector requires the following minimum scopes to establish a connection to Okta using authorization code grant authentication:
okta.logs.readokta.schemas.readoffline_accessopenid
View additional scopes
Select any additional scopes required for your use case from those defined in your Okta instance in Applications > Applications > Okta API Scopes. Select okta.users.read to connect using a custom role.
View default scopes
Workato requests the following default scopes if you don't select specific scopes:
okta.logs.readokta.schemas.readoffline_accessopenidokta.eventHooks.manageokta.users.manageokta.groups.manageokta.apps.read
# Create an app integration and secret for authorization code grant authentication
Complete the following steps to create an app integration and secret for authorization code grant authentication:
Sign in to your Okta organization as a user with administrator privileges.
Go to the Okta Admin Console and select Applications > Applications.
Click Create App Integration.
Find the Sign-in method section, and select OIDC - OpenID Connect.
Go to the Application type section and select Web Application.
Enter a unique App integration name on the New Web App Integration page.
Create a new app integration
Ensure the Require Demonstrating Proof of Possession (DPoP) header in token requests field is deselected.
Select the following checkboxes in the Client acting on behalf of a user field of the Grant type section:
- Authorization Code
- Refresh Token
Enter the Workato callback URI in the Sign-in redirect URIs section according to your data center:
- US Data Center:
https://www.workato.com/oauth/callback - EU Data Center:
https://app.eu.workato.com/oauth/callback - JP Data Center:
https://app.jp.workato.com/oauth/callback - SG Data Center:
https://app.sg.workato.com/oauth/callback - AU Data Center:
https://app.au.workato.com/oauth/callback - IL Data Center:
https://app.il.workato.com/oauth/callback - CN Data Center:
https://app.workatoapp.cn/oauth/callback - Developer sandbox:
https://app.trial.workato.com/oauth/callback
Select an Assignment option according to your preference and then select Save. Okta creates the app integration.
Go to the General tab and copy the Client ID and Client Secret so you can enter these credentials in Workato.
Copy the Client ID and Client Secret
Go to General Settings and ensure the Proof of possession field is deselected.
Go to the Okta API Scopes tab and assign the necessary scopes to the app integration. The connection requires the following scopes at a minimum:
offline_access and openid permissions are assigned automatically.
The connection requires the following additional scope if you are using a custom role:
okta.users.read
Assign Okta API scopes
# Connect to Okta using authorization code grant authentication
Complete the following steps to create an authorization code grant connection to Okta in Workato:
Click Create > Connection.
Search for and select Okta as your connection on the New connection page.
Provide a unique name for the connection in the Connection name field.
Name your connection
Use the Authentication type drop-down menu to select Authorization code grant.
Enter your Okta domain name in the Okta domain field. For example, mycompany.okta.com or mytest.oktapreview.com. Ensure that the domain name you enter doesn't include -admin, such as mycompany-admin.okta.com, as this URL is used to access the Okta admin console from the UI and isn't an OAuth endpoint.
Enter your Client ID.
Provide your Client secret.
Expand the Advanced settings section and use the OAuth 2.0 scopes drop-down menu to select additional OAuth 2.0 scopes for this connection. The scopes must match the scopes defined in your Okta instance in Applications > Applications > Okta API Scopes.
Workato requests the scopes you specify in addition to the minimum required scopes. Workato requests the default scopes if you don't select specific scopes.
# Client credentials authentication
Client credentials authentication requires creating an app integration and private key in Okta.
View client credentials connection setup steps
OAuth 2.0 scopes define the level of access Workato has to your Okta instance. Review the following sections to determine which scopes to assign to your app integration for OAuth 2.0 client credentials authentication. Your app integration must be assigned the Read-only Administrator role in Okta if your connection uses more than the minimum required scopes. If your app integration uses a custom role, you can assign it an applicable custom role instead.
View minimum scopes
The Okta connector requires the following minimum scopes to establish a connection to Okta using client credentials authentication:
View default scopes
okta.logs.readokta.schemas.readokta.eventHooks.manageokta.users.manageokta.groups.manageokta.apps.read
# Create an app integration and private key for client credentials authentication
Complete the following steps to create an app integration and private key for client credentials-based authentication:
Select API Services in the Sign-in method section of the Create a new app integration page.
Select API Services
Enter a unique App integration name and click Save on the New API Services App Integration page.
Enter an App integration name
Click Edit and select Public key / Private key in the Client authentication section.
Go to the Public keys section and click Edit.
Click Add key.
Click Generate new key to generate a new key pair.
Add a public key
Go to the Private key section and select PEM.
Click Copy to clipboard to copy the private key. Enter this key in Workato's Okta connection settings. You can't retrieve the private key again after leaving the page.
Click Done.
Click Save in the new app integration's General tab to store and activate the key. You must save the key before you can use it to connect to Workato.
Click Save if you see the message Existing client secrets will no longer be used.
The key status changes to Active.
Go to General > General Settings and ensure the Proof of possession field is deselected.
Go to the Okta API Scopes tab and assign the necessary scopes to the app integration. The connection requires the following minimum scopes:
okta.users.read
Go to the Admin roles tab and click Edit assignments.
Use the Roles drop-down menu to select Read-only Administrator or an applicable custom role.
Click Save changes.
# Connect to Okta using client credentials authentication
Complete the following steps to create a client credentials connection to Okta in Workato:
Use the Authentication type drop-down menu to select Client credentials.
Provide the private key generated in Okta in PEM format in the Private key field. Make sure to include -----BEGIN PRIVATE KEY----- and -----END PRIVATE KEY-----.
# API key-based authentication
API key-based authentication requires creating an API key in Okta.
View API key connection setup steps
# Generate an API key
API KEY PRIVILEGES AND LIMITATIONS
You must have administrator privileges in Okta to create an API key. Ensure that you're logged in as an administrator before you proceed.
Workato requires that the user and API key used in the connection have Organization Administrator or Super Administrator permissions. API keys inherit all permissions from the administrator who created them and can't be restricted to specific resources or operations. We recommend that you use a scoped OAuth 2.0 access token for improved security.
Refer to Create an API token (opens new window) for more information.
Complete the following steps to generate an API key in Okta:
Sign in to Okta.
Go to Security > API > Token.
Click Create token to generate an API key. The key inherits the permissions of the administrator who created it.
# Connect to Okta using API key-based authentication
Complete the following steps to create an API key connection to Okta in Workato:
Okta API key connection setup
Use the Authentication type drop-down menu to select API key.
Enter the API key generated in your Okta instance.
# How to use Okta End User MCP server tools
# get_my_user_profile tool
The get_my_user_profile tool retrieves your profile and organizational information. Your LLM uses this tool to provide detailed identity context, including your role, department, title, manager, and other profile attributes.
Try asking:
What's my official job title and department?Show me my Okta profile information.Who is my manager in Okta?What's my role and organizational information?
# list_assigned_applications tool
The list_assigned_applications tool retrieves the applications currently assigned to you. Your LLM uses this tool to show you what applications you can already access through Okta, helping you understand your current access permissions.
Try asking:
What applications do I have access to in Okta?Show me all my assigned apps.List the applications I can use.What tools and services can I access through Okta?
# get_application_sso_link tool
The get_application_sso_link tool retrieves the single sign-on (SSO) link for an application assigned to the authenticated user. Your LLM uses this tool to launch specific apps without navigating to the Okta UI.
Try asking:
Get me the SSO link to launch Salesforce.Give me the direct link to access Google Workspace.Open the SSO link for Zoom.How do I access the HR portal? Get me the link.
# Getting started
TOOLS MUST BE STARTED
Last updated: 3/27/2026, 4:02:14 PM
