# Connect to a source and destination for data pipelines
Data pipelines require a source to extract data and a destination to store replicated data. Set up both connections before you configure a pipeline.
After you configure connections, proceed to the Configure a data pipeline guide to set up and define sync settings.
# Supported sources and destinations
Data pipelines extract data from the following sources:
Data pipelines move data to the following destinations:
LIMITED AVAILABILITY
Workato supports the following data pipeline sources and destinations. Use these guides to configure each connection:
Contact your Workato representative for information.
Last updated: 8/18/2025, 5:05:32 PM
