# Create Salesforce leads from new HubSpot deals recipe
This use case guides you through connecting HubSpot, Salesforce, and Workbot for Microsoft Teams to create a powerful automation.
# What does this recipe do?
This recipe monitors HubSpot for new deals. If the deal is associated with a contact in HubSpot, the recipe creates a new lead in Salesforce, and Workbot for Microsoft Teams posts a message containing details about the new Salesforce lead.
# Create your recipe
Complete the following steps to build a recipe that creates Salesforce leads from new HubSpot deals:
Sign in to Workato.
Create connections for HubSpot, Salesforce, and Workbot for Microsoft Teams:
Create a HubSpot connection.
# Create a HubSpot connection
This step creates a connection between Workato and your HubSpot account.
Search for and select HubSpot on the New connection page.
Connect to HubSpot
Optional. Expand the Advanced settings section and use the Scopes drop-down menu to select permissions to request for the connection.
Optional. Select the profile for the connection in the Custom OAuth profile drop-down menu. Alternatively, create a new profile for HubSpot.
Select the HubSpot account where you plan to authorize Workato and click Choose Account.
Select an account
Create a Salesforce connection.
# Create a Salesforce connection
This step creates a connection between Workato and your Salesforce account.
Search for and select Salesforce on the New connection page.
Salesforce connection setup
Use the Auth type drop-down menu to select the authentication method. The default is OAuth 2.0.
Use the Sandbox drop-down menu to specify whether the Salesforce account is a sandbox account.
Optional. Expand Advanced settings to configure advanced connection options.
- This custom OAuth profile ensures that the connection is restricted to the same set of scopes you selected for all users with the profile, and the authentication flow uses the client app linked to the custom profile.
Enter your Salesforce account credentials and click Log In.
Log in to your Salesforce account
Create a Workbot for Microsoft Teams connection.
# Create a Workbot for Microsoft Teams connection
This step creates a connection between Workato and your Workbot for Microsoft Teams account.
Note: You must add Workbot to Microsoft Teams before you can establish the connection in Workato.
Search for and select Workbot for Microsoft Teams on the New connection page.
Image caption
Use the Auth type drop-down menu to select OAuth 2.0.
Optional. Expand the Advanced settings section to select permissions to request for the connection.
Optional. Select the custom OAuth profile for the connection in the Custom OAuth profile drop-down menu.
Click Sign in with Microsoft.
Create a new recipe
Set up your HubSpot New record (deal) trigger.
# Set up HubSpot New record (deal) trigger
This trigger monitors HubSpot for new deals and retrieves details about the amount and close date.
Search for and select the HubSpot connector.
Choose HubSpot
Select the New record trigger.
Select Deal from the Object drop-down menu.
Select deal properties to retrieve from the Properties drop-down menu. This example selects Amount and Close Date.
Configure the New deal trigger
Click Add step > Action in app
Set up your HubSpot Get associations action (batch).
# Set up HubSpot Get associations action (batch)
This step retrieves the contact associated with the deal that triggered the recipe.
Choose HubSpot
Select the Get associations batch action.
Select Deal from the From object drop-down menu.
Select Contact from the To object drop-down menu.
Map the HubSpot ID Step 1 datapill to the From object ID field.
Configure the Get associations action
Click + Add step and select IF condition.
Click Add step > IF condition
How do IF conditions work?
# HubSpot and Salesforce IF condition example
An IF condition lets you to make decisions based on specific conditions. You can control your recipe workflow by executing different actions depending on whether a condition you specify is true or false.
Set up your HubSpot IF condition.
# Set up a HubSpot IF condition
This step checks if a contact is associated with the new HubSpot deal.
Map the HubSpot List size Step 2 datapill (under the Results list) to Data field.
Select greater than from the Condition drop-down menu.
Enter 0 in the Value field.
Configure the IF condition
Click Select an app and action.
Set up your HubSpot Get record (contact) action.
# Set up HubSpot Get record (contact) action
This step retrieves information about the contact associated with the deal from HubSpot.
Choose HubSpot
Select the Get record action.
Select Contact from the Object drop-down menu.
Map the HubSpot To object ID Step 2 datapill to the ID field. This instructs the recipe to retrieve information about the contact associated with the new deal.
Specify the fields you plan to retrieve in the Fields to retrieve field. This example selects the following fields:
- Company Name
- Last Name
- Annual Revenue
- City
- Country/Region
- First Name
- Phone Number
- State/Province
- Job Title
You can select additional fields as required by your use case, or that you plan to sync when creating the lead in Salesforce.
Configure the Get contact action
Set up your Salesforce Create record (lead) action.
# Set up Salesforce Create record (lead) action
This step creates the lead in Salesforce using information about the contact from HubSpot.
Search for and select the Salesforce connector.
Choose Salesforce
Select the Create record action.
Select Lead from the Object drop-down menu.
Map datapills from the HubSpot Get contact action to the fields you plan to sync to the Salesforce lead. The Company and Last Name fields are required.
For example, this recipe maps the following HubSpot datapills to their respective Salesforce fields:
- Company Name Step 4 to the Company field.
- Last Name Step 4 to the Last Name field.
- Annual Revenue Step 4 to the Annual Revenue field.
- City Step 4 to the City field.
- Country/Region Step 4 to the Country field.
- Email Step 4 to the Email field.
- First Name Step 4 to the First Name field.
- Phone Number Step 4 to the Phone field.
- State/Region Step 4 to the State/Province field.
- Job Title Step 4 to the Title field.
Set up your Salesforce Get record details by ID action.
# Set up Salesforce Get record details by ID action
This step retrieves details about the new lead created in Salesforce.
Choose Salesforce
Select the Get record details by ID action.
Map the Salesforce Object ID Step 5 datapill to the Object ID field.
Configure the Get lead details by ID action
Set up your Workbot for Microsoft Teams Post message action.
# Set up Workbot for Microsoft Teams Post message action
This step posts a message in Microsoft Teams containing details about the new Salesforce lead.
Search for and select the Workbot for Microsoft Teams connector.
Choose Workbot for Microsoft Teams
Select the Post message action.
Select the channel where you plan to send the message from the Message recipient drop-down menu.
Locate the Message field and click Add block.
Fill out the following fields in the first block:
- Type: Select Text block.
- Block text: Enter
🔔 New Salesforce Lead Created!. - Text type: Select Header.
Click Add block.
Fill out the following fields in the second block:
- Block text: Enter
📌 Lead Name:and map the Salesforce Full Name Step 6 datapill. - Text type: Select Body text.
Click Add block.
Fill out the following fields in the third block:
- Block text: Enter
🏢 Company:and map the Salesforce Company Step 6 datapill. - Text type: Select Body text.
Click Add block.
Fill out the following fields in the fourth block:
- Block text: Switch this field to formula mode, enter
'📞 Phone: ' +, map the Salesforce Phone Step 6 datapill, and append the.to_phone(area_code: true)formula. - Text type: Select Body text.
Configure the phone block
Click Add block.
Fill out the following fields in the fifth block:
- Block text: Enter
✉️ Email:and map the Salesforce Email Step 6 datapill. - Text type: Select Body text.
Click Add block.
Fill out the following fields in the sixth block:
'💰 Deal Amount: ' +, map the HubSpot Amount Step 1 datapill, and append the.to_i.to_currencyformula. - Text type: Select Body text.
Configure the deal amount block
Click Add block.
Fill out the following fields in the seventh block:
'📆 Close Date: ' +, map the HubSpot Close Date Step 1 datapill, and append the.strftime("%m/%d/%Y")formula. - Text type: Select Body text.
Configure the close date block
Click Add block.
Fill out the following fields in the eighth and final block:
- Block text: Enter
🎯 Lead Source: HubSpot. - Text type: Select Body text.
Example message containing Salesforce lead details
Click Save.
Your Create Salesforce leads from new HubSpot deal recipe is ready to test and implement.
Example recipe configuration.
