# Project properties
Project properties are name-value pairs that enable you to store configuration parameters for use within a single project. Project properties are available in all recipes within the same project under the Properties datatree. You can also access project properties in the Workflow apps page editor Page data modal
Project properties are useful for complex deployment models across connections, recipes, and Workflow apps. For example, you can define a property that indicates a notification contact email. All recipes or Workflow app pages within the same project where the project properties exist can look up this value from the datatree and send an email to the same recipient.
Project properties are distinct from environment properties in that their scope is narrower. Environment properties are globally available within your Workato account, while project properties are available only at the project level in the specific project where you create and maintain them.
PROJECT PROPERTY JOB EXECUTION BEHAVIOR
Jobs do not dynamically detect and update changes to project property values. Project property values are frozen at the beginning of job execution by design. You can use Lookup tables if you require dynamic detection for project property values.
You can hide sensitive properties from common access by reducing the scope of users able to access projects containing sensitive properties.
# Permissions
Workato enables you to set granular permissions for both project properties and environment properties using role-based access control (RBAC) by creating a custom role.
Project property permissions are available in Workspace admin > Access control > Project roles > + Add project role.
Project properties privileges
Learn more about Project privileges.
# Limits
Project properties are subject to the following limits:
| Description | Limit |
| Maximum number of project properties per project | 1,000 |
| Maximum length of project property name | 100 characters |
| Maximum length of project property value | 1,024 characters |
FURTHER READING
Refer to the following guides to learn how to implement project properties:
Last updated: 1/6/2026, 7:38:13 PM
