# Google Workspace SAML configuration
This guide describes how to configure Google Workspace as a SAML identity provider (IdP) for Workato Identity.
SAML enables secure authentication between an IdP, such as Google Workspace, and a service provider like Workato. Users authenticate once through Google Workspace and gain access to Workato with a single login instead of managing separate credentials for each application.
PREREQUISITES
Workato Identity is available for Agent Studio, Workato GO, MCP, and the API developer portal.
Configure SAML-based authentication in Workato Identity before you begin. The Specify Single sign-on URL and Service provider (SP) entity ID values from that setup are required to complete the following steps.
Make sure you have super administrator privileges in Google Workspace.
# Configure SAML authentication in Google Workspace
Complete the following steps to configure SAML authentication in Google Workspace:
NOT FOR WORKFLOW APPS SAML-BASED SSO
This documentation is specific to Workato Identity. Refer to SAML-based single sign-on authentication to configure SAML authentication for Workflow apps.
Sign in to your Google Admin console (opens new window). You must be signed in as a super administrator.
Go to Apps > Web and mobile apps.
Click Add App > Add custom SAML app.
Enter a name for the app in the App name field. For example, Workato Agentic or MCP Servers.
Click Continue.
Go to the Google Identity Provider details page and download the IDP metadata or copy the following values for later use:
- SSO URL
- Entity ID
- Certificate
GOOGLE WORKSPACE METADATA
You may need to host your metadata file or verify if your Google Workspace tier exposes a metadata endpoint to provide a metadata URL in later steps.
Click Continue.
Go to the Service Provider Details window and paste the Single sign-on URL from Workato into the ACS URL field.
Paste the Service provider (SP) entity ID from Workato into the Entity ID field.
Click Continue.
Go to the Attribute Mapping section and click Add mapping to add the following attributes:
| Google Directory attribute | App attribute |
Basic Information > Full name | workato_end_user_name |
Employee Details > Department | workato_end_user_groups |
Click Finish.
Go back to Apps > Web and mobile apps and select your newly created app.
Click User access and set the service to On for everyone. Alternatively, you can configure access by organizational unit or group as required.
Click Save.
Return to the app's settings page and copy the Metadata URL, or use the IDP metadata file you downloaded in the previous steps. You must use this in the Do you have your identity provider metadata URL? section of the Set up a new provider modal in Workato Identity.
Go to your app's App Access Control to configure the settings to prevent users from seeing or launching the app directly.
DIRECT SIGN-IN FROM IDP UNSUPPORTED
You can't sign in to Workato directly from your IdP. Authentication is only supported when initiated through a conversation in your connected LLM.
Last updated: 4/14/2026, 3:25:07 PM
