# ELT Pipeline for Snowflake accelerator connections
The ELT Pipeline for Snowflake accelerator has eight connections that are common to both Slack and Microsoft Teams implementations:
In addition, this accelerator has two connections that are unique to either Slack or Microsoft Teams:
# ELT | CON | Snowflake through JDBC
Complete this connection using our JDBC connector documentation.
Complete this connection using our Snowflake connection setup documentation.
  • Choose an authentication type.
  • Select UTC timezone.
# ELT | CON | SQL Server through JDBC
Complete the connection using our JDBC connector documentation.
Complete this connection using our SQL server documentation.
# ELT | CON | SF Partner Account
Complete this connection using our Salesforce connector documentation.
# ELT | CON | S3
Complete this connection using our Amazon S3 connector documentation.
# ELT | CON | PostgreSQL through JDBC
# ELT | CON | On-prem-Files
Complete this connection using our On-prem files connector documentation.
# ELT | CON | Workbot for ELT Accelerator
Complete this connection using our Workbot for Slack documentation.
This connection is only required if you plan to implement the ELT Pipeline bot in Slack.
# ELT | CON | ELT Workbot for Microsoft Teams
Complete this connection using our Workbot for Microsoft Teams documentation.
This connection is only required if you plan to implement the ELT Pipeline bot in Microsoft Teams.
Last updated: 6/5/2025, 9:49:27 PM
