BambooHR
BambooHR is a HR software solution for collecting, maintaining, and analyzing your people data.
Review a BambooHR, QuickBooks Online, and Okta example recipe
Complete the following steps to create a recipe that monitors BambooHR for new employees. When activity is detected, it creates a new employee in QuickBooks Online and a new user in Okta.
This use case is intended to serve as an example. Recipe modifications such as trigger and action configuration and conditional logic may require adjustments if you plan to include this recipe in your own workflow.
Sign in to Workato.
Create connections for BambooHR, QuickBooks Online, and Okta.
Click Create > Recipe or press C+R.
Use the Location drop-down menu to select the project where you plan to store the recipe.
Click Start building.
Search for BambooHR and select it as your app.
Select the New employee trigger.
Select New employee as your trigger
Use the calendar modal to select the date from which your recipe should begin to monitor events in the When first started, this recipe should pick up events from field. The trigger checks for new events every five minutes by default. Leave this field empty to fetch events from the last hour. You can't change this value after you run or test the recipe.
Refer to Triggers to learn more about this input field.
Set up your trigger
Click Save.
Search for QuickBooks Online and select it as your app.
Choose QuickBooks Online as your app
Select Create employee as your action.
Map the BambooHR Mobile phoneStep 1 datapill into the Phone field and the BambooHR Work emailStep 1 datapill into the Email field.
Map the datapills for your action
Map the BambooHR First nameStep 1 datapill into the Given name field, map the BambooHR Last nameStep 1 datapill into the Family name field, and then map the BambooHR Display nameStep 1 datapill into the Display name field.
Map the BambooHR Employee numberStep 1 datapill into the Employee number field.
Map the Employee number datapill
Click Save.
Search for Okta and select it as your app.
Select the Create user action.
Select Create user as your action
Map the BambooHR First nameStep 1 into the First name field and the BambooHR Last nameStep 1 datapill into the Last name field.
Map the BambooHR Work emailStep 1 datapill into the Primary email ID field and the BambooHR Work emailStep 1 datapill into the Username field. The Username field must contain an email address.
Click Save.
Your BambooHR, QuickBooks Online, and Okta recipe is ready to test and implement.
API version
The BambooHR connector uses the Bamboo REST API v1.
Connection setup
The BambooHR connector supports the following authentication types:
API token
Use API token authentication to connect to BambooHR with a static key generated in the BambooHR portal.
Generate an API key in BambooHR
Complete the following steps to generate an API key before you connect in Workato:
Sign in to the BambooHR portal.
Go to My Account > API Keys.
Navigate to BambooHR API Keys
Create a new API key by selecting Add New Key.
Provide a descriptive name for this new API Key, for example, workato_user.
Save the generated API key in a secure location.
API KEY ONLY VISIBLE IN THIS STEP
You can't retrieve this key after this step.
Refer to the BambooHR documentation for more information.
Connect to BambooHR using API token
Complete the following steps to set up an API token connection to BambooHR in Workato:
Provide a unique name for the connection in the Connection name field.
Set up an API token connection
Use the Authentication type drop-down menu to select API Token.
Enter the API token you generated in Generate an API key in BambooHR in the API token field.
Enter your BambooHR subdomain in the Sub-domain field. This is most often your company name.
OAuth 2.0
Use OAuth 2.0 to connect to BambooHR without managing a static key. You authorize the connection through BambooHR when you connect.
Connect to BambooHR using OAuth 2.0
Complete the following steps to set up an OAuth 2.0 connection to BambooHR in Workato:
Set up an OAuth 2.0 connection
Use the Authentication type drop-down menu to select OAuth2.0.
Sign in to BambooHR when prompted and authorize access to complete the connection.
