# Column types
Data tables support columns of the following data types:
- Short text
- A single-line text field. Supports a maximum of 756 characters.
- Long text
- A multi-line text area. Supports a maximum of 10,000 (ten thousand) characters.
- Integer
- Any whole number.
- Decimal
- Any number.
- Boolean
- A true/false value.
- Date
- Values in Date format (day/month/year).
- DateTime
- Values in DateTime format (day/month/year) and (hours/minutes).
- File
- Upload or download files to/from your data tables.
- Maximum file size:
- 100MB
- Link to a table
- Display data from a different data table in your workspace.
- Linked data table
- Choose a data table to link to.
- Display data from
- Choose a column from the data table you have selected to use as a display name for the column.
# Available operands
This is a list of available operands you can use to filter your data table, based on column data type:
Short text
Available operands:
- Equals
- Is not equal to
- Is null
- Is not null
Long text
Available operands:
- Equals
- Is not equal to
- Is null
- Is not null
Integer
Available operands:
- Equals
- Is not equal to
- Is less than
- Is greater than
- Is less or equals
- Is greater or equals
- Is null
- Is not null
Decimal
Available operands:
- Equals
- Is not equal to
- Is less than
- Is greater than
- Is less or equals
- Is null
- Is not null
Boolean
Available operands:
- Is true
- Is false
- Is null
- Is not null
Date
Available operands:
- Equals
- Is not equal to
- Is before
- Is after
- Is on or before
- Is on or after
- Is null
- Is not null
DateTime
Available operands:
- Equals
- Is not equal to
- Is before
- Is after
- Is on or before
- Is on or after
- Is null
- Is not null
File
Available operands:
- Equals
- Is not equal to
- Is null
- Is not null
Last updated: 5/25/2023, 11:52:43 PM
