# Keyboard shortcuts
The following keyboard shortcuts enable you to manage table data using your keyboard. Keyboard shortcuts are available for both macOS and Windows operating systems.
# macOS shortcuts
- Show/hide the help menu
- command + s
- Save table
- command + space
- Select column
- shift + space
- Select record
- shift + ↑
- Select range of records (ascending)
- shift + ↓
- Select range of records (descending)
- command + i
- Insert column
- shift + enter
- Add record
- enter
- Edit selected cell
- command + ↑
- Jump to the edge of the table
- command + ↓
- command + →
- command + ←
- tab
- Move between cells (forward)
- shift + tab
- Move between cells (backward)
# Windows shortcuts
- ctrl + s
- Save table
- ctrl + space
- Select column
- shift + space
- Select record
- shift + ↑
- shift + ↓
- ctrl + i
- Insert column
- shift + enter
- Add record
- enter
- ctrl + ↑
- ctrl + ↓
- ctrl + →
- ctrl + ←
- tab
- shift + tab
Last updated: 9/11/2024, 4:23:13 AM
