Google Workspace
Google Workspace, formerly known as G Suite, is a collection of cloud computing, productivity, and collaboration tools developed by Google.
Workato's Google Workspace connector allows you to add, delete, update, fetch, or search for objects, such as users, groups, or roles. For example, when onboarding new employees, you can automatically add their details to Google Workspace.
FEATURE AVAILABILITY
The Google Workspace connector isn't available to workspaces in the CN data center. This reflects local regulatory requirements and applies to our multi-tenant and Virtual Private Workato (VPW) offerings.
API version
The Google Workspace connector uses the Google Admin SDK to connect to admin services.
How to connect to Google Workspace
The Google Workspace connector supports the following authentication methods:
SERVICE ACCOUNT AUTHENTICATION
You can use a service account to authenticate without a personal user account. For consistent use, Workato recommends service account authentication.
OAuth 2.0 authentication
Complete the following steps to connect to Google Workspace using OAuth 2.0 authentication:
Search for and select Google Workspace as your connection.
Optional. Expand the Advanced settings section and select OAuth 2.0 scopes to request for your connection.
Workato requests the following scopes by default in addition to the scopes you select:
DescriptionScope requested
View and manage the provisioning of users on your domainadmin.directory.user
View and manage organization units on your domainadmin.directory.orgunit
View and manage the provisioning of domains for your customersadmin.directory.domain
View and manage the provisioning of user schemas on your domainadmin.directory.userschema
View and manage the provisioning of groups on your domainadmin.directory.group
View and manage group subscriptions on your domainadmin.directory.group.member
View and manage data transfers between users in your organizationadmin.datatransfer
Manage your mobile devices by performing administrative tasksadmin.directory.device.mobile.action
View audit reports for your Google Workspace domainadmin.reports.audit.readonly
View usage reports for your Google Workspace domainadmin.reports.usage.readonly
Manage delegated admin roles for your domainadmin.directory.rolemanagement
Manage data access permissions for users on your domainadmin.directory.user.security
Refer to the Google Directory API scopes or OAuth 2.0 Scopes for Google APIs guide for more information about scopes.
Click Sign in with Google.
Connect to Google WorkspaceConnect to Google Workspace
Sign in with your Google account. Your Google account must have admin privileges to make organization-wide changes in Google Workspace.
Click Allow to enable Workato to access your Google account.
Enable Workato to access your Google accountEnable Workato to access your Google account
Service account authentication
A Google service account is a specialized Google account associated with a Google Cloud Project (GCP) that can run API requests on your behalf.
Service accounts provide the following benefits:
  • Continuous operation: Service accounts ensure that operations continue even if individual user permissions change.
  • Dedicated permissions: Service accounts can only access projects that you share with them.
  • Dedicated API quotas: You can manage a service account's API quotas through GCP and request quota increases directly from Google.
Refer to the Google service account documentation to learn more about service accounts.
Set up a Google service account
Complete the following steps to set up a Google service account:
Create a service account in your GCP project.
Go to IAM & Admin > Service accounts. Ensure your dashboard is scoped to the project that contains your service account. Check the scope of your dashboard.Check the scope of your dashboard.
Click the Email of the service account you intend to use. Click the email of the service account you intend to use.Click the Email of the service account you intend to use.
Copy the service account's Email and save it to configure your connection later.
Copy the account's emailCopy the account's Email.
Go to the KEYS tab.
Generate a private key and download it in JSON format. You can only download the key once.
Open the JSON file, then copy the entire private key from -----BEGIN PRIVATE KEY----- to -----END PRIVATE KEY-----\n (inclusive) and save it to configure your connection later.
You must enable the Google Workspace API to complete the connection setup.
REQUIRED SCOPES FOR SERVICE ACCOUNT AUTHENTICATION
Ensure that you have the following required permissions to successfully connect to Google Workspace using a service account:
  • admin.directory.user
  • admin.directory.orgunit
  • admin.directory.domain
  • admin.directory.group
  • admin.directory.group.member
  • admin.datatransfer
  • admin.directory.device.mobile.action
  • admin.directory.userschema
  • admin.reports.audit.readonly
  • admin.reports.usage.readonly
  • admin.directory.rolemanagement
  • admin.directory.user.security
The service account impersonates the user based on the email address you provide during the connection setup after authentication is complete.
Complete setup in Workato
Complete the following steps to connect to Google Workspace using service account authentication:
Service account authentication requires the following prerequisites:
Provide a unique name for the connection in the Connection name field.
Use the Authentication type drop-down menu to select Service account.
Enter the service account's email address in the GCP project service account email field.
Retrieve your GCP Project service account emailRetrieve your GCP Project service account email
Enter the Private key and User email. Retrieve the private key from the downloadable JSON. Include both the -----BEGIN PRIVATE KEY----- to -----END PRIVATE KEY-----\n.
