Activity audit log reference ​
This guide provides a comprehensive list of activities recorded in activity audit logs, organized into categories such as account management, connections, API collections, and workflow apps.
Account activities ​
Activities related to the Workato account, including user logins, password and email updates, account setting modifications, and actions related to Embedded customer workspaces. Each activity indicates whether it applies to Embedded workspaces, direct use cases, or both.
ActivityDescriptionActivity type
User loginUser logged in through SSO or using a password. See an example. Embedded and direct
User login failedUser login attempt failed. Select the activity to find out if the user was logging in through SSO or using a password. See an example. Embedded and direct
User logoutUser logged out of Workato.Embedded and direct
Password changedUser changed their password by going to Profile settings > Password.Embedded and direct
User switched workspacesUser switched to another workspace. In audit logs for the workspace the user switched to, this is shown as User login. Select the activity to view the value of the Activity attribute in the details section; a value of switch_workspace indicates the user switched to another workspace.Embedded and direct
Account email updatedUser updated their email by going to Profile settings > Profile and modifying the Account email field.Embedded and direct
User name updatedUser updated their username by going to Profile settings > Profile and modifying the Name field.Embedded and direct
Password reset requestedUser requested to reset their password by clicking Forgot password? during login. In the next screen, by providing the email and clicking the Reset password user confirms the intent to reset their password.Embedded and direct
Enabled two-factor authenticationUser enabled two-factor authentication by going to Profile settings > Two-factor authentication.Embedded and direct
Disabled two-factor authenticationUser disabled two-factor authentication by going to Profile settings > Two-factor authentication and clicking Disable two-factor authentication.Embedded and direct
Viewed two-factor authentication recovery codesUser viewed the two-factor authentication recovery codes by going to Profile settings > Two-factor authentication and clicking View recovery codes.Embedded and direct
API key refreshedUser refreshed the API token used to connect to Workato platform APIs by going to Workspace admin > API clients, selecting their API client, and regenerating their API token.Embedded and direct
Error notifications email updatedUser updated the list of emails receiving error notifications from Workato by going to Workspace admin > Settings > Error alerts and entering emails in the Recipients field.Embedded and direct
Error notification throttlingUser enabled or disabled notification throttling by going to Workspace admin > Settings > Error alerts and clicking the Quota error alerts to one per hour for each recipe toggle.Embedded and direct
Audit log streamingUser enabled or disabled audit log streaming. You can configure this setting by going to Workspace admin > Settings > Log streaming. Additionally, the Workato system automatically disables audit log streaming if it detects that the ALR (Audit Log Receiver) connection has been manually disconnected by a user in the workspace for more than eight (8) hours.Embedded and direct
Audit log streaming data inclusionUser updated audit log streaming contents by selecting or deselecting one or more options under Choose events to stream in Workspace admin > Settings > Log streaming.Embedded and direct
Audit log streaming destination updatedUser updated the destination where streaming audit logs are sent by going to Workspace admin > Settings > Log streaming and updating the Audit log destination field.Embedded and direct
Authentication method updatedThe authentication method for the workspace was updated by going to Workspace admin > Settings > Login methods. Available authentication methods include Workato authentication (no additional authentication), SAML SSO, and Two Factor Authentication.Embedded and direct
SAML SSO setting savedSAML SSO configuration is successfully configured, verified, and saved by a user in Workspace admin > Settings > Login methods. Available SAML providers include Okta, OneLogin, and other SAML IdP.Embedded and direct
SAML SSO enforcement enabledA user enabled SAML SSO enforcement for the workspace by navigating to Workspace admin > Settings > Login methods and toggling Enforce SAML authentication for all users. Embedded and direct
SAML SSO enforcement disabledA user disabled SAML SSO enforcement for the workspace by navigating to Workspace admin > Settings > Login methods and toggling Enforce SAML authentication for all users.Embedded and direct
Roles sync via SAML SSO enabledA user enabled roles sync via SAML SSO for the workspace by navigating to Workspace admin > Settings > Login methods and toggling Enable role syncing.Embedded and direct
Roles sync via SAML SSO disabledA user disabled roles sync via SAML SSO for the workspace by navigating to Workspace admin > Settings > Login methods and toggling Enable role syncing.Embedded and direct
SAML SSO Just-in-time (JIT) provisioning enabledSAML SSO Just-in-time (JIT) provisioning was enabled for the workspace by going to Workspace admin > Settings > Login methods and toggling Enable SAML JIT provisioning.Embedded and direct
SAML SSO Just-in-time (JIT) provisioning disabledSAML SSO Just-in-time (JIT) provisioning was disabled for the workspace by going to Workspace admin > Settings > Login methods and toggling Enable SAML JIT provisioning.Embedded and direct
Environment switchedUser switched to another AHQ Environment (DEV, PROD, or TEST). This information is only visible from your organization's DEV Environment.Embedded and direct
Workspace createdAn Embedded customer workspace was provisioned.Embedded only
Environment provisionedEnvironments were enabled for a specific customer workspace.Embedded and direct
Plan detail updatedThe usage plan details were updated, such as a change in the plan type, quotas, or trial account configuration.Embedded only
App access updatedApp access for an Embedded customer workspace was updated.Embedded and direct
Custom OAuth profile assignment createdA custom OAuth profile was assigned to a customer workspace.Embedded only
Custom OAuth profile assignment created (environments)A custom OAuth profile was assigned to a specific environment within a customer workspace.Embedded only
Custom OAuth profile assignment removedA custom OAuth profile assignment was removed from a customer workspace.Embedded only
Custom OAuth profile assignment removed (environments)A custom OAuth profile assignment was removed from a specific environment within a customer workspace.Embedded only
External ID updatedThe external ID for a customer workspace was updated.Embedded only
External ID updated (environments)The external ID for a specific environment within a customer workspace was updated.Embedded only
Embedding configuration updatedThe origin URL or frame ancestor settings for an Embedded customer workspace were updated.Embedded only
Workspace deletedAn Embedded customer workspace was deleted.Embedded only
Workspace deleted (environments)A specific environment within a customer workspace was deleted.Embedded only
Customer manager assignedA customer manager was created and assigned to customer workspace(s).Embedded only
Customer manager removedA customer manager was removed from customer workspace(s).Embedded only
Customer manager updatedA customer manager assignment was updated.Embedded only
Shared connector deployedA shared connector was deployed to customer workspaces.Embedded and direct
Shared connector redeployedA shared connector was redeployed with an updated version to customer workspaces.Embedded and direct
Shared connector removedA shared connector was removed from customer workspaces.Embedded and direct
Enabled audit log streamingAudit log streaming was enabled in the Admin console for all customer workspaces.Embedded only
Branding updatedThe branding of admin and customer workspaces was updated.Embedded only
User login example ​
User login
User login failed example ​
User login failed
Workspace activities ​
Activities related to Workspace collaborators, including collaborator invitations, roles, and member modifications.
ActivityDescription
Invite createdUser invited a collaborator by going to Workspace admin > Access control > Collaborators and clicking Invite collaborator. See an example.
Invite acceptedUser accepted the invite to join the workspace by clicking the Accept invite button in the invitation email. See an example.
Invite modifiedUser modified the invitation in the Workspace admin > Access control > Pending invitations tab.
Invite canceledUser canceled the invitation sent to a collaborator by clicking the Delete button in the Workspace > Collaborators > Pending invitations tab.
Role updatedUser updated a collaborator's role by going to Workspace admin > Access control > Collaborator roles and changing the role.
Member deletedUser deleted a workspace member by clicking the Delete button in the Workspace admin > Access control > Collaborators tab.
Role createdUser added a new custom role by going to Workspace admin > Access control > Collaborator roles and clicking Add new role.
Permissions changed for roleUser changed the permissions for a custom role by going to Workspace admin > Access control > Collaborator roles, selecting a custom role and editing the role's permissions. You can view the updated and previous permissions in JSON format by copying them from the activity log and pasting them into a text editor. See an example.
Role deletedUser deleted a custom role by going to the Workspace admin > Access control > Collaborator roles tab and clicking the Delete button.
Workspace name changedUser changed the name of the workspace by going to Workspace admin > Settings > General and editing the Workspace name field.
Invite created example ​
Invite workspace member
Invite accepted example ​
Workspace member joined
Updated custom role permissions example ​
You can view the updated and previous permissions of a custom role by clicking Copy. You can then paste the copied JSON into a text editor or other application to view the permissions.
Updated role permissions
Recipe activities ​
Activities related to recipes.
ActivityDescription
StartedUser started a recipe by clicking the Start recipe button from the Recipe details page. The activity log includes the folder path where the recipe was started.
StoppedUser stopped a recipe by clicking the Stop recipe button from the Recipe details page. See an example The activity log includes the folder path where the recipe was stopped.
CreatedUser created a new recipe by clicking Create > Recipe or pressing C+R. The activity log includes the folder name where the recipe was created. The activity log includes the folder path where the recipe was created.
EditedUser modified a recipe by going to the Recipe details page, editing, and saving the recipe. The activity log includes the folder path where the recipe was edited.
RenamedUser renamed a recipe by clicking the recipe title, editing, and saving it. The activity log includes the folder path where the recipe was renamed.
MovedUser moved a recipe from one folder to another by dragging and dropping the recipe from the Recipes page. The activity audit log includes the folder path where the recipe was moved to and from.
Cloned/CopiedUser cloned a recipe by clicking ... > Clone recipe in the Recipes page or clicking the Copy button in the Recipe details page. The activity log includes the folder path where the recipe was copied/cloned.
Access scope updatedUser updated the access scope (public or private) of a recipe by toggling the Is this a public recipe setting found in the Recipe details > Settings tab. The activity audit log includes the folder path where the recipe's access scope was updated.
DeletedUser deleted a recipe by clicking ... (ellipsis) > Delete recipe in the Recipes page or clicking the Delete button in the Recipe details page. The activity log includes the folder name where the recipe was deleted.
Tag added to recipeUser added one or more tags to a recipe.
Tag removed from recipeUser removed one or more tags from a recipe.
Recipe stopped example ​
Recipe stopped
Connection activities ​
Activities related to connections.
ActivityDescription
Connection createdUser created a new connection by clicking Create > Connection or pressing C twice. The activity log includes the folder name where the connection was created.
Connection editedUser edited an existing connection by going to the Connections page or the Recipe details > Connections tab, disconnecting the connection, and then modifying its settings. The activity log includes the folder name where the connection was edited.
Connection connectedUser connected an account to or provided credentials for a connection in its Connection settings page. The activity log includes the folder name where the connection was connected.
Connection disconnectedUser disconnected a connection by clicking the Disconnect button in its Connection settings page. See an example. The activity log includes the folder name where the connection was created.
Connection deletedUser deleted a connection by going to Connections, selecting a connection, and clicking Delete connection. The activity log includes the folder name where the connection was deleted.
Connection movedUser moved a connection from one folder into another folder by dragging and dropping it to a new destination. The activity log includes the folder name where the connection was moved to and from.
Tag added to connectionUser added one or more tags to a connection.
Tag removed from connectionUser removed one or more tags from a connection.
Connection disconnected example ​
Tag activities ​
Activities related to tags.
ActivityDescription
Tag createdUser created a new tag.
Tag deletedUser deleted an existing tag.
Tag updatedUser modified an existing tag by editing properties such as the tag name, color, or description.
Tag created example ​
Tag createdTag created
Folder activities ​
Activities related to folders.
ActivityDescription
Folder createdUser created a new folder by clicking Create > Folder or pressing C+F. See an example.
Folder deletedUser deleted a folder by clicking ... (ellipsis) on the folder and selecting Delete from the menu. See an example.
Folder renamedUser renamed a folder by clicking ... (ellipsis) on the folder and selecting Rename from the menu.
Folder movedUser moved a folder by dragging and dropping it to a new destination.
Folder created example ​
Folder created
Folder deleted example ​
Folder deleted
Package activities ​
Activities related to Recipe lifecycle management manifests and packages and deployments across Environments.
ActivityDescription
Manifest createdUser created a new manifest by going to Tools > Recipe lifecycle management and clicking Create new manifest.
Manifest updatedUser updated an existing manifest by going to Tools > Recipe lifecycle management > Export tab, selecting a manifest, and clicking the Edit manifest button.
Manifest deletedUser deleted a manifest by going to Tools > Recipe lifecycle management > Export tab, selecting a manifest, and clicking ... > Delete manifest.
Package exportedUser exported a package by going to the Recipe lifecycle management page and creating, building, and packaging the manifest to a .zip file.
Package importedUser imported a package by going to Tools > Recipe lifecycle management > Imports tab and clicking Import package to a new folder.
Project deployedUser with the Environments feature enabled successfully deployed a project from the DEV environment to another environment, such as TEST or PROD.
Connector SDK activities ​
Activities related to the Connector SDK.
ActivityDescription
Custom connector createdUser created a new connector by going to Tools > Connector SDK and clicking Create connector.
Custom connector updatedUser updated a connector by going to Tools > Connector SDK, selecting the connector, and modifying its source code.
Custom connector releasedUser released a new version of the latest connector changes by going to Tools > Connector SDK, selecting the connector, clicking Release latest version.
Custom connector deletedUser deleted a connector by going to Tools > Connector SDK, selecting the connector, and clicking Delete.
Common data model activities ​
Activities related to Common data models.
ActivityDescription
Common data model createdUser created a new data model by going to Tools > Common data models and clicking Create a new data model.
Common data model updatedUser updated a data model by going to Tools > Common data models, selecting the data model, and modifying it.
Common data model deletedUser deleted a data model by going to Tools > Common data models, selecting the data model, and clicking Delete data model.
Lookup table activities ​
Activities related to Lookup tables.
ActivityDescription
Lookup table createdUser created a new lookup table by going to Tools > Lookup table and clicking Create a new lookup table.
Lookup table updatedUser updated a lookup table by going to Tools > Lookup table, selecting the lookup table, and modifying it.
Lookup table deletedUser deleted a lookup table by going to Tools > Lookup table, selecting the lookup table, and clicking Delete table.
Lookup table truncatedAll rows were deleted.
CSV importedA CSV was used to import rows.
CSV exportedLookup table was exported as CSV.
Lookup table was movedA user moved a lookup table from one folder into a different folder by navigating to Tools > Lookup tables, selecting a lookup table, and updating its availability.
Message template activities ​
Activities related to Message templates.
ActivityDescription
Message template createdUser created a new message template by going to Tools > Message templates and clicking Create a new template.
Message template updatedUser updated a message template by going to Tools > Message templates, selecting the message template, and modifying it.
Message template deletedUser deleted a message template by going to Tools > Message templates, selecting the message template, and clicking Delete template.
Properties activities ​
Activities related to Environment properties and Project properties.
ActivityDescription
Environment property was createdUser created a new environment property by going to Tools > Properties and clicking Add new property.
Environment property was updatedUser updated an environment property by going to Tools > Properties, clicking the Edit button for the property, and modifying it.
Environment property was deletedUser deleted an environment property by going to Tools > Properties and clicking the Delete button for the property.
Project property was createdUser created a new project property by going to Projects, selecting a project, navigating to Settings > Project properties, and clicking Add new property.
Project property was updatedUser updated project property by going to Projects, selecting a project, navigating to Settings > Project properties, selecting a property, and clicking Edit.
Project property was deletedUser deleted a project property by going to Projects, selecting a project, navigating to Settings > Project properties, selecting a property, and clicking Delete.
Event topic activities ​
Activities related to Event topics.
ActivityDescription
Event topic createdUser created a new event topic by going to Platform > Event streams and clicking Create a new topic.
Event topic updatedUser updated an event topic by going to Platform > Event streams, selecting the topic, and modifying it.
Event topic deletedUser deleted an event topic.
Event topic movedUser moved an event topic to a different project or folder. The activity log includes the project or folder path where the event topic was moved to and from.
Event topic retention changedUser updated the message history retention period of an event topic from the topic's Settings tab.
Event topic schema updatedUser updated the schema of an event topic.
Event topic resetUser reset an event topic, clearing its message history, by opening the topic's Settings tab and clicking Reset.
API collection activities ​
Activities related to API collections.
ActivityDescription
API collection createdUser created an new API collection by going to Platform > API platform > API collections tab and clicking + Create new collection.
API collection updatedUser updated an API collection by going to Platform > API platform > API collections tab, clicking ... > Edit collection for the collection, and modifying it.
API collection deletedUser deleted an API collection by going to Platform > API platform > API collections tab and clicking ... > Delete collection for the collection.
API endpoint activities ​
Activities related to API endpoints.
ActivityDescription
API endpoint createdUser created a new API endpoint by going to Platform > API platform > API collections tab, selecting an API collection from the list, and clicking Create a new endpoint.
API endpoint updatedUser updated an API endpoint by going to Platform > API platform > API collections tab, selecting an API collection from the list, clicking ... > Edit endpoint for the endpoint, and modifying it.
API endpoint deletedUser deleted an API endpoint by going to Platform > API platform > API collections tab, selecting an API collection from the list, and clicking ... > Delete endpoint for the endpoint.
API endpoint activatedUser activated an API endpoint by going to Platform > API platform > API collections tab, selecting an API collection from the list, selecting an API endpoint from the collection, and toggling to activate.
API endpoint deactivatedUser deactivated an API endpoint by going to Platform > API platform > API collections tab, selecting an API collection from the list, selecting an API endpoint from the collection, and toggling to deactivate.
API client activities ​
Activities related to API clients.
ActivityDescription
API client createdUser created a new API client by going to Platform > API platform > Clients tab and clicking Add new client.
API client updatedUser updated an API client by going to Platform > API platform > Clients tab, clicking ... > Edit client for the customer, and modifying it.
API client deletedUser deleted an API client by going to Platform > API platform > Clients tab and clicking ... > Delete client for the customer.
API access profile activities ​
Activities related to API access profiles.
ActivityDescription
API access profile createdUser created a new API access profile by going to Platform > API platform > Clients tab, selecting a client from the list, and clicking Create access profile.
API access profile updatedUser updated an API access profile by going to Platform > API platform > Clients tab, selecting a client from the list, clicking ... > Edit access profile for the access profile, and modifying it.
API access profile deletedUser deleted an API access profile by going to Platform > API platform > Clients tab, selecting a client from the list, and clicking ... > Delete access profile for the access profile.
API access profile key refreshedUser refreshed an API key associated with an API access profile by going to Platform > API platform > Clients tab, selecting a client from the list, and clicking Refresh.
API policy activities ​
Activities related to API policies.
ActivityDescription
API policy createdUser created a new API policy by going to Platform > API platform > Policies tab and clicking Create new policy.
API policy updatedUser updated an API policy by going to Platform > API platform > Policies tab, selecting a policy from the list, clicking ... > Edit policy for the policy, and modifying it.
API policy deletedUser deleted an API policy by going to Platform > API platform > Policies tab, selecting a client from the list, and clicking ... > Delete policy for the policy.
Workflow apps activities ​
Activities related to Workflow apps, including app setup, pages, and data tables.
Note that the activity log tracks all builder-side (Workato) related activity. All user activity in the Workflow apps portal is tracked in the panel of a request.
ActivityDescription
App createdA user created a new Workflow app by going to Projects > Create project and selecting the option Build an app.
App configuration changedA user changed the configuration of a Workflow app by selecting a project and navigating to Settings > Workflow app setup and updating the settings.
App was publishedA user published a Workflow app by selecting a project, navigating to Settings > Workflow app setup and clicking Go live.
Portal URL was changedA user changed the Workflow apps portal URL by navigating to Platform > Workflow apps portal > Portal settings > General and updating the Portal URL.
Portal was renamedA user renamed the Workflow apps portal by navigating to Platform > Workflow apps portal > Portal settings > General and updating the Portal name.
Portal authentication settings were changedA user changed the Workflow apps portal authentication settings by navigating to Platform > Workflow apps portal > Portal settings > Security and updating the Authentication method.
Embedding settings of {App name} were changed. Embedding was enabled.A user enabled embedding portal pages for a particular Workflow app by navigating to Platform > Workflow apps portal > Portal settings > Security > Embedding and toggling Enable iframe embedding and then clicking Save changes.
Embedding settings of {App name} were changed. Embedding was disabled.A user disabled embedding portal pages for a particular Workflow app by navigating to Platform > Workflow apps portal > Portal settings > Security > Embedding and toggling Enable iframe embedding and then clicking Save changes.
Portal branding settings were changedA user changed the branding settings by navigating to Platform > Workflow apps portal > Portal settings > Branding and updating the brand logo, brand color, or text color.
User group was createdA user created a user group by navigating to Platform > Workflow apps portal > Users and groups and clicking the + (plus) to create a group.
User group was renamedA user renamed a user group by navigating to Platform > Workflow apps portal > Users and groups, clicking the ... (ellipsis), and selecting Rename group.
User group was deletedA user deleted a user group by navigating to Platform > Workflow apps portal > Users and groups, clicking the ... (ellipsis), and selecting Delete group.
Portal user was invited and added to user groupA user invited a new user to the Workflow apps portal by going to Platform > Workflow apps portal > Users and groups and clicking Invite user. By default, Workato adds new users to the Everyone group. The activity log specifies whether the user added the new user to additional user groups.
Portal user was added to user groupA user added another user to a particular user group, as specified in the activity log, by navigating to Platform > Workflow apps portal > Users and groups, selecting a Group and clicking Add users to this group.
Role was assigned to user group in {Workflow app}A user assigned a user group to a particular Workflow app with the role Member or Manager by selecting a project, navigating to Settings > Workflow app setup > User groups and clicking + add group.
Role was unassigned from user group in {Workflow app}A user unassigned a user group from a particular Workflow app by selecting a project, navigating to Settings > Workflow app setup > User groups, clicking the delete icon next to a user group, and then clicking Save.
Role for user group in {Workflow app} was changedA user changed the role of a specific user group assigned to a particular Workflow app by selecting a project, navigating to Settings > Workflow app setup > User groups and updating the user group's role. Available roles are Member and Manager.
Workflow stage was createdA user created a new workflow stage for an app in Projects > Settings > Workflow app setup.
Workflow stage was editedA user edited a workflow stage for an app by selecting a project, going to Settings > Workflow app setup, selecting an existing workflow stage, and clicking Update stage.
Workflow stage was deletedA user deleted a workflow stage for an app by selecting a project, going to Settings > Workflow app setup, selecting an existing workflow stage, and clicking Delete stage.
Page was createdA user created a Page using one of two methods. They either opened a project and then clicked Create and selected Page from the drop-down. The other way they could have created a page was by using the App creation wizard by going to Projects and clicking Create project and then selecting Build an app. When you create a Workflow app using this method, Workato automatically creates the necessary Page(s) for your workflow.
Page was renamedA user renamed a Page by selecting a Page from within a project, clicking the ... (ellipsis) and selecting Rename page.
Page was editedA user edited a Page by selecting a Page from within a project, updating the Page using the Page editor and then clicking Save.
Page was deletedA user deleted a Page by selecting a Page from within a project, clicking the ... (ellipsis) and selecting Delete page.
Tag added to PageA user added one or more tags to a Page.
Tag removed from PageA user removed one or more tags from a Page.
Data table was createdA user created a data table by either creating the table manually at the recipe level or by using the App creation wizard by going to Projects and clicking Create project and then selecting Build an app. When you create a Workflow app using this method, Workato automatically creates the necessary data table(s) for your workflow.
Data table was renamedA user renamed a data table by selecting a data table from within a project and then clicking the pen icon to update the name.
Data table was deletedA user deleted a data table by selecting a data table from within a project and then clicking Delete table.
Record was added to data tableA user added a record to a data table by selecting a recipe and going to Data tables and adding a record. This activity is only captured in situations where a user makes a change in the Workato UI. It does not track changes made by a recipe.
Record was edited in data tableThis activity is only captured in situations where a user makes a change in the Workato UI. It does not track changes made by a recipe.
Record was removed from data tableA user removed a record from a data table by selecting a data table, clicking on a record within the data table, and then clicking Delete. This activity is only captured in situations where a user makes a change in the Workato UI. It does not track changes made by a recipe.
Structure of data table was modifiedA user modified the structure of a data table by adding, deleting, or editing a data table column in the Workato UI. Workato does not track changes made to table structure by a recipe.
Tag added to data tableA user added one or more tags to a data table.
Tag removed from data tableA user removed one or more tags from a data table.
On-prem group activities ​
Activities related to on-prem groups, including group creation, settings, and deletion.
ActivityDescription
On-prem group createdUser created a new on-prem group.
On-prem group renamedUser renamed an on-prem group.
On-prem group setting updatedUser updated an on-prem group setting.
On-prem group deletedUser deleted an on-prem group.
On-prem agent activities ​
Activities related to on-prem agents, including agent creation, activation, and lifecycle changes.
ActivityDescription
On-prem agent createdUser added a new on-prem agent to an on-prem group.
On-prem agent activatedUser registered an on-prem agent with an activation code.
On-prem agent renamedUser renamed an on-prem agent.
On-prem agent disabledUser disabled an on-prem agent.
On-prem agent enabledUser enabled a disabled on-prem agent.
On-prem agent deletedUser deleted an on-prem agent.
