# New record trigger
This trigger runs when a new record is created in a data table.
# Input fields
Input field | Description |
Choose a data table | Select a data table to search for new records. |
When first started, this recipe should pick up events from | Get new records starting at a specific date/time. If you leave this field empty, the default condition is to retrieve new records from one hour ago. You cannot change this value after you run or test the recipe. Learn more about this input field. |
# Trigger conditions
You can use trigger conditions to filter out only the new records that are important to your workflow.
- Change ID
- The ID number that corresponds to the change in the data table.
- Change time
- The date and time the new record was added to the data table.
- Record
Includes all fields from the object. This includes the following columns Workato auto-generates and additional columns you customize in your data table.
- Record ID
- The unique ID of the record.
- Created at
- The creation time of the record.
- Updated at
- The last edit time of the record.
Last updated: 9/11/2024, 4:23:13 AM
