# Remove values from record action
This action removes the columns values you select from a record in a data table.
# Input fields
Input field | Description |
Data table | The data table in which you plan to make changes. |
Record ID | The ID of the record from which you plan to remove values. Workato automatically generates a unique ID for each record in a data table. You can obtain the Record ID by viewing the Record ID column in the data table, which is hidden by default. |
Values to be removed | The field values you plan to remove. Note that required fields cannot be selected as their values cannot be removed. |
Output field | Description |
Record | The fields removed from the record, including the following fields: Record ID, Created time, and Last modified time. |
Last updated: 9/5/2024, 1:09:52 AM
