# Formula troubleshooting
This guide helps you solve specific problems in Workato recipes. Each scenario shows how to use formulas to transform, validate, and process data effectively.
# Transform multiline text into a comma-separated string
Some systems, such as Salesforce or text exports, store data with line breaks (\n) to separate values. Target systems often require data in a single, comma-separated format.
# Solution
Complete the following steps to transform a multiline text input into a comma-separated string:
Go to the recipe step with a field that accepts multiline text input.
Activate Formula mode in the field where you plan to transform the multiline text.
Enter the following formula to replace the line breaks with commas:
<TextField>.gsub("\n",",")
Replace <TextField> with the relevant datapill or static multiline text.
# Remove duplicates in a comma-separated string
Data sources often produce strings with duplicate values, such as Apple, Banana, Apple. These duplicates can cause errors or inconsistencies in downstream systems that require unique values.
# Solution
Complete the following steps to remove duplicates from a comma-separated string:
Go to the recipe step with a field that accepts a comma-separated string.
Activate Formula mode in the field where you need to clean up duplicates.
Enter the following formula to split the string into an array, remove duplicates, and rejoin it as a cleaned string:
<TextField>&.split(“,”)&.uniq&.join(", ")
Replace <TextField> with the relevant datapill or static string.
# Split comma-separated strings into arrays
Some systems provide data as a comma-separated string. Target systems often require this data as individual items for multi-picklist fields or other processing steps.
# Solution
Complete the following steps to split a comma-separated string into an array:
Activate Formula mode in the field where you need to split the string.
Enter the following formula to split the string into an array:
<TextField>.split(",")
# Join arrays into line-break-separated strings
Some systems provide data as an array of strings. Target systems often require this data in a line-break-separated format for text fields or custom logs.
# Solution
Complete the following steps to join an array of strings into a line-break-separated format:
Go to the recipe step with a field that accepts array input.
Activate Formula mode in the field where you plan to transform the array.
Enter the following formula to join the array into a line-break-separated string:
<Array>.join("\n")
Replace <Array> with a relevant datapill or static array.
# Transform an array into a comma-separated string
Dynamic fields often return data as arrays of values. Target systems that require text inputs often need this data as a single, comma-separated string.
# Solution
Complete the following steps to convert an array of strings into a single, comma-separated list:
Enter the following formula to transform the array into a comma-separated string:
<Array>.join(", ")
# Convert date strings to date format
Some sources provide dates as strings, such as MM/DD/YYYY. Target systems often require these dates in a proper format for calculations or comparisons.
# Solution
Complete the following steps to convert a date string into a proper date format:
Go to the recipe step with a field that accepts date input.
Activate Formula mode in the field where you plan to convert the date string.
Enter the following formula to convert the string into a date format:
<Date>.to_date(format:“MM/DD/YYYY”)
Replace <Date> with the relevant datapill or static date string. Ensure the format inside format: "MM/DD/YYYY" matches the actual structure of the input string.
# Extract first item from an array
Some systems return arrays, even when they contain only one value. Target systems often require just the first item for further processing or as a standalone value.
# Solution
Complete the following steps to extract the first value from an array:
Activate Formula mode in the field where you plan to extract the first item.
Enter the following formula to extract the first value from the array:
<Array>.first
# Truncate a string to fit field length
Target systems often enforce strict character limits, such as 255 characters. Strings that exceed these limits can cause errors during updates.
# Solution
Complete the following steps to truncate a string to fit a field’s length limit:
Go to the recipe step with a field that accepts text input.
Activate Formula mode in the field where you plan to truncate the string.
Enter the following formula to truncate the string:
<Text>.slice(0, 255)
Replace <Text> with the relevant datapill or static string, and adjust 255 to match the character limit of your target system.
# Validate field length
Some systems, such as Salesforce, require fields like opportunity IDs to match a specific length. Validating the length ensures data integrity before further processing.
# Solution
Complete the following steps to validate a field’s length:
Add an IF Condition step in your recipe.
Activate Formula mode in the Data field where you plan to check the field’s length.
Enter the following formula to calculate the field’s length:
<Field>.length
Replace <Field> with the relevant datapill or a static string.
Set the condition to compare the field length with the target value. For example:
  • Equals 18 to validate Salesforce opportunity IDs.
  • Greater than 0 to ensure the field is not empty.
# Convert a date to a different format
Some systems require dates in specific string formats for logs, reports, or user-facing fields. Convert the source date into a compatible format to meet system or audience needs.
# Solution
Complete the following steps to convert a date into a different format:
Go to the recipe step with a field that accepts a date input.
Activate Formula mode in the field where you plan to reformat the date.
Enter the following formula to reformat the date:
<Date>.strftime("%A, %B %d")
Substitute <Date> with the relevant datapill or static date string, and adjust the format string ("%A, %B %d") to match your desired output. For example, if <Date> contains 2025-01-05 (in YYYY-MM-DD format), the formula will output Monday, January 05.
# Example of different formats
The strftime method allows you to customize date formats for different use cases. The following table displays common date formats and their corresponding output:
Format Formula Output for 2025-01-05
Full date <Date>.strftime("%A, %B %d") Monday, January 05
Shortened date <Date>.strftime("%b %d, %Y") Jan 05, 2025
ISO format <Date>.strftime("%Y-%m-%d") 2025-01-05
European format <Date>.strftime("%d/%m/%Y") 05/01/2025
Date with time <Date>.strftime("%B %d, %Y at %H:%M") January 05, 2025 at 00:00
# Populate field based on a condition
Some systems require fields to reflect specific values based on set conditions. Dynamically adjust the field’s value to ensure it meets the criteria for downstream processing.
# Solution
Complete the following steps to populate a field based on a condition:
Go to the step in your recipe where the field accepts the input.
Activate Formula mode in the field where you plan to apply the condition.
Enter the following formula in the field:
<Field>&.scan(/(ValueToSearchFor)/).present? ? "ValueIfTrue" : "ValueIfFalse"
Replace the following placeholders in the formula:
  • <Field>: Replace with the datapill or static value representing the input field.
  • ValueToSearchFor: Replace with the term you plan to search for in the field.
  • ValueIfTrue: Replace with the value to populate if the condition is true.
  • ValueIfFalse: Replace with the value to populate if the condition is false.
Last updated: 1/28/2025, 5:02:56 PM
