# ELT Pipeline for Snowflake accelerator - Assets - Lookup tables
The ELT Pipeline for Snowflake accelerator has seven lookup tables that are common to both Slack and Microsoft Teams implementations of the accelerator:
- ELT | User Access
- ELT | Systems
- ELT | Objects
- ELT | JOB TABLE
- ELT | ERROR LOGS
- ELT | CONTROL TABLE | MAIN
- ELT | CONTROL TABLE | CHILD
# ELT | User Access
The ELT | User Access lookup table contains the following fields:
- The user's email address.
- Active
- The pipeline's status.
- Pipelines Pinned
- The pipelines the user has pinned to their App homepage.
- Role
- The user's role. Admin or Analyst.
# ELT | Systems
The ELT | Systems lookup table contains the following fields:
- SYSTEM_ID
- References the SYSTEM_ID in the ELT | Systems lookup table.
- SYSTEM
- The source system.
- TYPE
- The type of application (source).
- CREATED_BY
- The email address of the person who created the object.
- CREATED_ON
- Date when the object was created.
# ELT | Objects
The ELT | Objects lookup table contains the following fields:
- SYSTEM_ID
- OBJECT
- The object used for the pipeline.
- CREATED_BY
- CREATED_ON
- PRIMARY_KEY
- Custom Primary Key for SQL-type sources.
# ELT | JOB TABLE
The ELT | JOB TABLE lookup table contains the following fields:
- ELT_CONTROL_ID
- Unique ID auto-generated when you create a pipeline. This ID corresponds to the ELT_CONTROL_ID in the **ELT | CONTROL TABLE | MAIN** lookup table.
- JOB_ID
- Unique Job ID of the running pipeline.
- BATCH_START_DT
- Start date-time of the job.
- BATCH_END_DT
- End date-time of the job.
- ROWS_AFFECTED
- Total Rows processed. (Salesforce only)
- IS_SUCCESS
- This value indicates whether the job was successful. Boolean value (true/false).
- DISPATCHER_JOB_URL
- Job URL of the evaluated workload.
- WORKLOAD_JOB_URL
- Job URL of the respective workload called by the dispatcher.
# ELT | ERROR LOGS
The ELT | ERROR LOGS lookup table contains the following fields:
- ELT_CONTROL_ID
- Unique ID auto-generated when you create a pipeline. This ID corresponds to the ELT_CONTROL_ID in the ELT | CONTROL TABLE | MAIN lookup table.
- JOB_ID
- ERROR_MSG
- Error message on failure.
- ERROR_CODE
- Error code of failure. Use to determine reprocessing logic.
- JOB_URL
- URL of the failed job.
- ACTION
- Dependent on the error code. Use to determine reprocessing logic. Actions can include notifications.
# ELT | CONTROL TABLE | MAIN
The ELT | CONTROL TABLE | MAIN lookup table contains the following fields:
- ELT_CONTROL_ID
- SOURCE_SYSTEM_NAME
- Source system where the data originates.
- SOURCE_OBJECT_NAME
- Name of the desired data entity. This is usually a table or file name in the case of file source systems.
- TARGET_TABLE_NAME
- The table where the accelerator loads the data.
- LOAD_TYPE
- Type of the load.
- Allowed values:
- Full, incremental, or extract.
- STATUS
- Pipeline status.
- Allowed values:
- Pending, Active, Inactive, Error, Processing, or Extract
- COMM
- Communication channel (Slack or Microsoft Teams)
- CREATED_BY
- Email of the user who created the pipeline.
- UPDATED_BY
- Email of the user who updated the pipeline.
# ELT | CONTROL TABLE | CHILD
The ELT | CONTROL TABLE | CHILD lookup table contains the following fields:
- ELT_CONTROL_ID
- PIPELINE_CREATED_DT
- Date when the pipeline is created.
- PIPELINE_UPDATED_DT
- Date when the pipeline is updated.
- HOUR
- Hour of the day selected.
- MINUTE
- Minute of the hour of the day selected.
- FREQUENCY
- How frequently the pipeline runs.
- Allowed values:
- Daily, Weekly, Monthly, Hourly, or Yearly
- START_TIME
- The time when the user schedules the pipeline to start.
- NEXT_TIME
- The next time the pipeline must run.
- LAST_SUCCESSFUL_JOB_URL
- Jobs are sub-tasks in a pipeline. The accelerator records them on the first and subsequent runs. The accelerator updates this value when a job finishes successfully.
- LAST_SUCCESSFUL_JOB_DT
- Last time the job ran successfully.
Assets
Last updated: 2/22/2024, 11:17:11 PM
